Need help! possibly torque managment
I have a hci 06 Z06. The issue I have was that when I pushed the traction control button it would go off. But the active handling would still engage. Seen if you unplug the steering angle sensor it would go away and not come on anymore. This worked fine for a short period. Now If you get wheelspin from a slight roll it will come on good then automatically bog the car down. Doest show anything on the dic when this happens. But Ive also noticed if you do a powerbrake this doesnt happen. Has anyone had this issue before?
Received 1,194 Likes
St. Jude Donor '15
Hold down the traction control button for 10-15 seconds. It will turn active handling off too.
Try that and see what happens
What is making you think it's active handling causing this ?
Do u have a stick or and auto , torque management is only active in an auto and limits 1ST to 2nd gear hp to 380 and 2nd to 3rd to 390 to 400
Traction control on the other hand would cause the symptoms you describe as it will just help pulling power till it does not sense wheel spin
Dave
Dave
I am willing to bet it is something in your tune that is causing the bog
Have you done a data log ????
