KR when revving?
KR when revving?
Just playing around with the VCM scanner today and noticed I get some knock retard when I free rev the car in neutral or with the clutch in. There's an occasional blip of KR under load when WOT, but nowhere near as much as when I just rev it. 2006 Z06 H/C/I and I didn't tune it. Anyone know what's going on? Is this normal on the LS7?
Attached are a log of revving then some WOT, and another log of just a couple revs.
Received 1,194 Likes
St. Jude Donor '15
Not out of the ordinary in my opinion. I didn't see anything over 1*. Assuming the knock settings aren't completely out in left field then I wouldn't worry about it. When you see real knock it will be much higher and stay around longer. Again, assuming tuner didn't do too much to the knock settings
St. Jude Donor '13
Is there knock when driving the in the same rpm/load ranges?
Normal.
You'll chase your tail and land up with a car that makes no power if you try to make it so KR is always zero. A random blip every once and awhile is completely normal.
The second file has over 3° of KR. Is the exhaust touching the frame or other solid part somewhere and rattling or some sort of vibration that the engine or knock sensor is picking up? Looks like the 20-21° of commanded timing at the higher rpm range is same as my car but the KR is pulling it back.
Thanks!
St. Jude Donor '15
Agree w/Unreal
I did that on my truck and it was damn near dangerous to drive it was so slow.
My 08 will ping if i am driving 55-60 in 6th gear (auto)and i try and accelerate more when the elevation of the road increases.(slight hill).Seems that it should shift down or the computer should compensate on the timing.
St. Jude Donor '15
No.
Tech 11 sounds so futuristic and cool.
