Zo6 441 MAP / MAF problems
Hi there , has been a while since I checked in but what to say the only place to get solutions is here .
To start with I have recently replaced my pcm car runs fine
Went to get tune unfortunately the tuner wasn't able to tune my car 300 shot though he gave me N/A tune , so I went back home wating for arrival of a well experienced tuner from abroad
And then These cods shows up : P103 , P101
So what I did I replace mass air flow sensors and MAP
But still nothing change I still get the codes and when I get them the car is not drivable please any advice will be appreciated
Modifications :
Ls7 441
Gt 21 cam
Prc heads
Direct port fast
Modifications :
Ls7 441
Gt 21 cam
Prc heads
Direct port fast
Post the tune, or wait for the tuner.
What map sensor is in there?
Received 1,193 Likes
St. Jude Donor '15
Holy **** that's a jacked up spark table
He did nothing for MAF high table, just messed with a few cells in the MAF low table
Get it tuned. That is the problem.
St. Jude Donor '15
St. Jude Donor '15
It's possible there's another problem, sensor wiring, etc.. but tuner should be able to figure that out quickly if he's even halfway decent at it
sure I will keep all the options in my mind step by step eliminating till I fix my problem , its just I have to wait for someone to help me with tune as no much of local tuners .
thanks
