Help With HP Tuners Scan
I recently took my heavily modded 2012 GS (736 RWHP) to the strip for the first time. I met a fellow C6 guy there who had HP Tuners software on his laptop and was kind enough to log a run for me. I don't have the software so he took photos of the PC screen and sent them to me. The run is over two photos. I have never seen this graph before so assuming someone can read the graphs I would appreciate an analysis of the run. It was a lousy run as the NT05R 345/30/19 DR's provided almost no traction as I spun almost the entire first 1/8 mile and the car did not run as I would have expected even given the traction problems. It looks to me among other issues the shift points are screwed up as the car was on the 7,000 rev limiter from launch through the traps. Any help will be appreciated.
BIGMAC
BIGMAC
It did shift 1-2-3-4 but I think the RPM shift point was right on the rev limiter. Perhaps the shift was being triggered buy the speed part of the shift algorithm.
Received 1,194 Likes
St. Jude Donor '15
Not enough there to say much other than it looks like someone flat lined a chuck of the spark table.
There are also quite a few little blips on the timing that are probably either KR or burst KR doing it's thing.. can't tell without more info
I was running 50% 93 octane pump gas 50% 100 octane race gas, spraying 100% meth and ambient temp was 80 deg. so I would hope not to be needing KR, When the motor hits the rev limited does it pull timing?
St. Jude Donor '15
That could def be it. Can use spark and/or throttle and/or fuel for rev limiter depending on how it's setup
The shifts are definitely associated with the speed settings. Timing could be pulled on rev limiter depending on the settings. Also could be pulled on shifts depending on torque management settings.
I see a burnout, then the full run with all the gearshifts in the tracer window at the bottom of the scanner screen (actually top BC the snaps are upside down), then his coast down. Doesn't add anything to the discussion BC the photo snaps are somewhere in the middle of the run with pretty scarce PIDS.
Guessing, but looks like the first screen is close to a second to third gear shift, next screen is third or fourth getting wound out. Just a 4 second slice between screens of his total run. Both screen snaps are 7K rpm so I'm thinking those are KR notches in the timing.
BIGMAC
BIGMAC
BIGMAC
With this pic, if it isn't KRs then your rev limiter is triggered by timing advance.
