C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Wide Band for Each Bank?
Old 02-28-2017, 06:48 PM
Trention
Trention's Avatar
Default Wide Band for Each Bank?
Any recommendations on running two separate wide bands for the HP Tuners set-up? Not sure I see a need but I'm a sucker for symmetry.
Old 02-28-2017, 08:27 PM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
A pair of aem 30-0333s
Old 03-01-2017, 07:22 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
That's what I'd do ^
Old 03-02-2017, 06:53 PM
Trention
Trention's Avatar
I noticed that the factory CAT sensor is on the left down pipe so I'll most likely go with a single AEM on the right down pipe to start with.
Old 03-02-2017, 06:54 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Factory has sensor on both banks before cats and sensors on both banks after cats.
Old 03-02-2017, 08:45 PM
Dcasole
Dcasole's Avatar
Received 2,241 Likes on 1,634 Posts
schpenxel, should you run two wide band sensors ?
Dave
Old 03-03-2017, 08:13 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
There's not really anything you can do to adjust one bank vs. the other, so I guess the only purpose would be to see if there's an issue. Those types of issues (i.e. injector way out of balance from the rest or vacuum leak) typically show up as big fuel trim differences anyways, so not sure an extra wideband would really be worth it
I usually just run one in the drivers side which is supposedly the leaner bank. Probably better idea to run it in the X pipe so you get both banks but I haven't gotten around to doing that
I mean.. more data is almost always better.. but you can't really do a whole lot with it if there isn't anything wrong and one bank is just a little different than the other, and there are other ways to spot common issues, so I don't think it's worth it for most regular people. Just my opinion though, I'm sure some will disagree.
Dcasole (03-03-2017)
Old 03-03-2017, 08:39 AM
BlindSpot
BlindSpot's Avatar
Received 1,368 Likes on 907 Posts
completely. Besides not being of much use in a tune function BC you cannot fuel or time half of the motor with only one MAF and one VE, it would be a little crazy to impossible to read out two WBs simultaneously. Difficult/messy to do with analog WBs and Dashlogic; or, you'd need two AFR gauges.
Might only serve to more quickly ID a bad injector or misfire if P codes haven't already caught it, and manifold vac leaks will impact both sides, etc.
Old 03-03-2017, 10:45 AM
Dcasole
Dcasole's Avatar
Thanks gentlemen !
Dave
To Wide Band for Each Bank?
Quick Reply: Wide Band for Each Bank?
