Dyno and Tune
Dyno and Tune
I recently had a battery issue and believe my tune has been lost.
Is there anybody left in Southern California that still uses a dyno and HP software to do custom tuning?
Many thanks.
Many thanks.
Received 1,194 Likes
St. Jude Donor '15
Unless it was reflashed then you didn't lose anything.
No reason it should be lost, but take it to Ryne@CMS if you need a tune. Only place in Socal I would let touch a car.
St. Jude Donor '13-'14-'15
You will never lose your tune for any reason-----HOWEVER any time your battery voltage goes low or the battery is dead---you lose all the "learning" that your ECM has done to correct the P/T fueling to achieve the Stoich AFR of 14.68
This learning process typically takes 50-75 miles of normal driving to finish---The more modded your engine is the longer it takes
PS A car that has minor bolt on mods like a CAI and cat back exh will add airflow--At P/T ts is no big deal however at WOT the added fuel trims from your mods will also be added to your WOT fueling as a lean saftety---Not un common even with a CAI to have your fuel trims add 15% more fuel at P/T to achieve the 14.68 AFR BUT this % is also added to your WOT fueling as well as a built in lean safety---This will make your engine pig rich an lazy at WOT-----Eventually like I mentioned this added fuel will "learn out" and your fuel trims will settle on "0" at P/T and at WOT there won't be any additional fuel added that made it rich and lazy----Tuning will immediately correct the fuel trims so there is no driving for 50-75 miles to allow the fuel trims yo learn on their own
