Service Bulletins, TSB, Recall - Your help please
Forum Members,
I am about to take my 2006 C6 into the local Chevy dealership for its first visit. I understand there is a problem with the Pulley that needs to be addressed for my VIN number series.
My question:
What other Bulletins, Recalls, or TSB should I be prepard to discuss with the service manager to get addressed at the same time?
My car was build in Sept/Oct 2004 with a VIN of 3190.
THANKS in advance!!!
My question:
Don't want to scare you or anything, but here they are.
Technical Service Bulletins - Search Results
Report Date : April 29, 2005
SEARCH TYPE : VEHICLE
YEAR : 2005
Make : CHEVROLET
Model : CORVETTE
Type : PASSENGER CAR
Make : CHEVROLET Model : CORVETTE Year : 2005
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 030844005B Date of Bulletin: JAN 01, 2005
NHTSA Item Number: 10005588
Component: VISIBILITY DEFROSTER/DEFOGGER SYSTEM:REAR WINDOW
Summary:
POOR RADIO RECEPTION OR RADIO STATIC/ INCREASED INTERFERENCE WITH REAR WINDOW DEFOGGER ON OR SOME REAR WINDOW DEFOGGER GRIDS MAY BE INOPERATIVE. *TT
Service Bulletin Num : 050601001 Date of Bulletin: JAN 01, 2005
NHTSA Item Number: 10013469
Component: ENGINE AND ENGINE COOLING
Summary:
CHECK GAGES LIGHT BATTERY VOLTAGE LOW ACCESSORY DRIVE BELT SLIPPING OR MISSING. *EH
Service Bulletin Num : 3242 Date of Bulletin: NOV 09, 2004
NHTSA Item Number: 10011749
Summary:
OIL LEAK AT OIL COOLER LINES. *EH
Service Bulletin Num : 040729003 Date of Bulletin: OCT 21, 2004
NHTSA Item Number: 10010513
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
MISMACHINED TRANSMISSION COUNTERSHAFT SNAP RING GROOVE. *TT UPDATED *EH
Service Bulletin Num : 030851001 Date of Bulletin: OCT 01, 2004
NHTSA Item Number: 10004390
Component: STRUCTURE:BODY
Summary:
TRANSSEAL TEMPORARY PROTECTIVE COATING REMOVAL INSTRUCTIONS. *TT BULLETIN 03-08-51-001, DATED 09/01/2003 REPLACED. *TT
Service Bulletin Num : 009072004 Date of Bulletin: SEP 07, 2004
NHTSA Item Number: 10013190
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
TRANSMISSION SHIFT INTO REVERSE PRIOR TO SHUTTING OFF THE VEHICLE. *EH
Service Bulletin Num : 040089041 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10011067
Component: OTHER
Summary:
PRE-DELIVERY AND SERVICE GUIDE. *TT
Service Bulletin Num : 040601025 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10011204
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
EXCHANGE PROGRAM FOR 2005 MODEL YEAR ENGINES. *TT
Service Bulletin Num : 07062004 Date of Bulletin: JUL 06, 2004
NHTSA Item Number: 10013181
Component: EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
Summary:
CORVETTE NEW PRODUCT VIDEO. *EH
Service Bulletin Num : 3173 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10010557
Summary:
WATER LEAK ON DRIVERS FLOOR. *EH
Service Bulletin Num : 3132 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10010628
Component: SUSPENSION:REAR:SHOCK ABSORBER
Summary:
LOWER REAR SHOCK ATTACHING BOLT MAY BREAK AFTER TORQUED. *TT
Service Bulletin Num : 3199 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10010635
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM
Summary:
INFORMATION ON LOW COOLANT MESSAGE. *TT
Service Bulletin Num : 3225 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10011626
Component: ELECTRICAL SYSTEM
Summary:
PROGRAMMING PROCEDURE FOR THE REMOTE CONTROL DOOR LOCK RECEIVER. *EH
Service Bulletin Num : 3219 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10011654
Summary:
UNABLE TO PROGRAM TRANSMISSION CONTROL MODULE AFTER REPLACEMENT. *EH
Service Bulletin Num : 3235 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10011720
Summary:
ENGINEERING INVESTIGATION ON THE NEW TRANSMISSION CONTROL MODULE. *EH
Service Bulletin Num : 3359 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10013549
Summary:
YEAR : 2005
Make : CHEVROLET
Model : CORVETTE
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Component: OTHER
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Location: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
those are only the bulletins and recall info. from the NHTSA. There are others but somehow are only found if you have the problems and are lucky enough to have it researched prior to work, etc.
for example, there is a bulletin (just release about a week ago) about early production (before dec.) MN6s that have a weak clutch.
Originally Posted by spectra6.0
You mean there are more? Like this wasn't enough!
I have an M6 ( August '04 ) . haven't noticed any slippage. What are the details on that TSB?
the gm tsb number is 05-07-31-001 April 8, 2005
Originally Posted by Zig
the tsb for the clutch is for early production clutches and high rpm shifts. shifting over 6k will cause the clutch to stick to the floor.
Haven't noticed anything like that .....Yet! Just another thing to keep my eye on.
So your saying the clutch won't disengage when red lining? The pedal itself actually does not come up? That's interesting!
C'mon guys. There are TSB's out for just about every vehicle in production. These refer to problems that have been observed and diagnosed, and provide a reference for a service department if one of the problems shows up. It doesn't mean that you'll ever see the problem, just if you do there's a solution available.
We've already gone through the MN6 panic, and now the crank pulley bolt hysteria. Overall reliability on the car has been excellent, it's just very easy to lose sight of that at times. Sometimes, too much knowledge is not a good thing.
Originally Posted by 6speedC6
Damn that list is is three times longer then the one on my 03 cobra and I thought it was bad!!!!!
Originally Posted by 05_C6Z51
Maybe Chevy operates with a better disclosure policy then Ford?
FORD has poor customer service from my experience
Don't know, but if I get the service from Gm I got from Ford I will be a Happy Customer!
So far I have had my clutch replaced to the new one since I had the high RPM problem and my battery was cracked. They replaced it too. The Crank Pully was ok.
How can I be sure I don't have that clutch problem?? Is there a way I can test it ??? What exactly were the symptoms?
Thanks in advance.
Thanks in advance.
kinda kills the run if you know what i mean...
