Rear End From C5 In C6?
Premium Supporting Vendor
Anyone heard if a C5 rear center will fit in a C6? I read that somewhere & I'm hoping to put a built rear from a C5 in my 6
Jason
Texas Speed
Jason
Texas Speed
These pictures are of the mounting bolt pattern for both the early 2005 differential and the C5 differential that some people have put on the C6. It appears that the bolt pattern for the C5 and early 2005 carriers are identical making the switch to the C5 differential for those with the weakest 2005 C6 differential only require the switch to a modified mounting bracket for the C5 rear. Note: if you can already mount a 2006 diff to your 2005 C6 then you can't mount the C5 diff directly without changing the rear part of the transmission that mates to the carrier.
The C5 rear uses a center mounting bracket with 2 bolts that come out of both the top and bottom of a separate rubber mount. The mounting of the C6 rear is on the sides of the carrier and cause more stress to the casing.
To mount the centrally located bolts requires the drilling for the new mount location. A separate peice could be used to connect the C6 mounting locatios for the outgoing C6 carrier. It appears much less involved than previously beleived since the rear casing of the transmission is the same for those with the weakest casing.
What if you just swap the end castings with the different mounting brackets from the early C6 onto the C5 unit? I have a very early 05 C6 and was thinking of using my Z06 carrier out of my C5 too.
I had thought about that as I beleive the reason they are breaking is due to the wing mounts rather than the case exploding from weakness, however, the case doesnt accept the center mounting bracket from the C5's rear and it would require a weld. The core is 700 bucks for the C5 so it isnt as big a deal. The C6 core will be of value to those that did break one and don't want to go through the process of this swap. At 2050 for the C6 core, the swap will pay for itself.
GM will eventually revise this issue eventually since they are having to pay for it in the form of warranty work.
Wouldn't it seem that some sort of gridle for the case to distribute the load on the case would solve this problem? Where are the cases cracking? I thought that the force of the ring and pinion was what was cracking the cases. I am very interested in this because I have 4.10 gears installed and this would most likey leave me to cover the cost if it breaks. I had these installed before I found out about the cases busting. Does anybody have any pictures of a broken case?
Collections Hold
http://www.dynotech-eng.com/dte_c6_diff_strut.htm
So again, If I have a 3:42 ZO6 C5 rear and I want to use it in my very early (June of 04) built 2005 C6 can I just pull the ends of the case off of my C6 rear diff and bolt them in place on my C5 3:42 ZO6 diff and Iam good to go? I dont need the C5 mount anymore if Iam putting them in my C6. Iam not worried about strength, my car will be very mildly modded and will not run slicks. I will take the chance something might break and deal with it if it happens.
If anyone wants to buy a brand new DTE brace in the DTE link above, I have one new in the box, unused for 325 shipped. They have been shown in practice to add to the strength of the case and even in the event of diff failure it holds the assmebly together so as to not take other parts with it such as the transmission output shaft. The C6 strut is different in design than the C5 strut and therefore will not work with my diff swap plans.
I plan on riding out my diff until it breaks, if it breaks...I'll probably buy your brace and hope to make it through the summer. I just hate the pain in installing them. I'm hoping my easy launches will win out.
