Towing a C6
Old 05-01-2006, 05:54 PM
TOPGON
TOPGON's Avatar
Default Towing a C6
Obviously the best way to tow a C6 is with a caul hauler / trailer. I plan to tow my C6 on a tow dolly as others have as it will be short distances to shows. Any consturctive input from those with tow dolly experience is appreciated.
Old 05-01-2006, 08:17 PM
AU N EGL
AU N EGL's Avatar
I do a lot of towing / hauling. Best to use a trailer, u-haul or other and not a tow dolly. But if it is a short distance why not just drive it??
It will get dirty either way and you will still need to clean it before judging??
Old 05-01-2006, 08:39 PM
TOPGON
TOPGON's Avatar
I tow with a show truck and show both vehicles which is why the tow dolly operation is the easiest for my one man operation.
Old 05-01-2006, 08:51 PM
youngs98
youngs98's Avatar
I am about to tow my car on a uhaul trailer from GA to OK. Is it possible to back it on due to the low front end...or should I just stack some 2x6s under the front tire to lift the air dam above the front of the trailer? Also, I think I will have to climb out the window once it's on the trailer because I don't think I will be able to open the doors. Any suggestions appreciated.
Old 05-01-2006, 10:51 PM
shurite44
shurite44's Avatar
You fellows should either do a search or start a thread in the drag race section. Lots of those guys tow their C6's. A fellow named Jerry had a C6 on a U-haul trailer at a race near Columbus.
I don't think you are going to find to many guys putting their C6's on a tow dolly though. My cousin uses a dolly for his drag car. I follow him usually in my car and I would not trust one with my C6. They just don't trail very true.
Old 05-02-2006, 07:59 AM
AU N EGL
AU N EGL's Avatar
I use a 24' enclosed car hauler with 60" ramp extensions on the rear drop down door. Still very tight clearnances when loading.
any trailer is a one person opporation, just take the time to lean how to do it correctly.
Use t-hooks that attach into the jacking puck holes on the frame and 5000 lbs tie downs.
Old 05-02-2006, 02:23 PM
ipmtim
ipmtim's Avatar
Cruise-In VIII Veteran
St. Jude Donor '06
I used to tow my front wheel drive car behind our motorhome. I wouldn't use the tow dolly on my C6. For one you cannot back up with it hooked up and I feel the car is much safer on the trailer especially if you need to take evasive action
Old 05-02-2006, 08:28 PM
6 speed Sid
6 speed Sid's Avatar
I have used a dolly a couple of times. Not the best, but works ok for me.
To Towing a C6
Quick Reply: Towing a C6
