Top speed in each gear?
on a C6 6MN with Z51 option
First gear to redline is = ???mph
Second gear = ???
Third gear = ???
etc...
Real life numbers from track runs, of course.
Second gear = ???
Third gear = ???
etc...
M6 is 56 84 116 150 203 at 6,500
A6 is 50 85 131 174 236 at 6,500
I can say the A6 1-3 #'s are close but I have only been ~170 so have not needed 5th.
You can do the math for Z51
Gear ratios A6 effective........Z51 effective.....M6 effective
1........... 4.02.......10.29.......2.97 10.16 .......2.66 9.10
2........... 2.36.......6.04.........2.07 7.08.........1.78 6.09
3........... 1.53.......3.92.........1.43 4.89.........1.30 4.45
4........... 1.15.......2.94.........1.00 3.42.........1.00 3.42
5........... 0.85.......2.18.........0.71 2.43.........0.74 2.53
6........... 0.67.......1.72.........0.50 1.71.........0.57 1.95
Final drive............2.56................3.4 2................3.42
Sorry, my search showed up nil.
Must be operator's error.
Can you post?
Can you post?
Originally Posted by ShawnDFW
Drag racing, I guess. Trying to find out the theoritical and real life potential of my car.
Originally Posted by AU N EGL
Drag racing?? Road Courses?? LSR ?
Sorry i don't get it?? can't be the speed in each gear? No way the 400hp C4 will do 56mph in 1st, nor 203 top speed??
Must be I'm dense!
Must be I'm dense!
Must be I'm dense!
So are these real ife top speed numbers? Given that top speed is drag limited from 214 to 189 per Chevy's claim, what are the REAL numbers per each gear?
Originally Posted by dbratten
Speeds are correct for a C6. With Z51 the trans ratios are wider and the speeds are 51, 73, 106, 152, 214 @ 6500 RPM. Top speed is drag limited and 6th gear isn't listed at all as the car slows down vs. 5th gear.
'Kay,
I'll go out tomorrow and try to pull 51 mph in 1st. And if blow a rod or the tranny, I'll send you the bill.
Car will pull redline in first four gears although I only took my A6 to 6000 in 4th before shifting. 5th keep climbing. It should do the claimed 186 top speed but it will be in 5th and not 6th when it does given no mods.
Second gear = ???
Third gear = ???
etc...
Second gear = ???
Third gear = ???
etc...
On each gear go to about 3250 RPM, then multiply the speed by two. Works on every gear. Unfortunately the car will not redline on 5th and 6th gear. I believe on 5th, the car will top out at 186MPH at 6000 RPM
'Kay,
Not to worry. I've had mine bouncing off the rev limiter with no damage. But it's more fun to test the limiter in 4th.
'Kay,
And mine just bounces off the rev limiter no drama like older cars.
Originally Posted by haljensen
The only "claimed" 186 MPH is for the stock Manual 6 spd Z51 geared C6 in 5th gear, the standard 6 spd manual is less and the 4spd and 6 spd automatics are less.
I would expect that the A6 would be a little slower though due to transmission loss. I can't see why the non-Z51 MN6 would be slower. The Z51 should be around 5,600 rpm at 186 and the non-Z51 at around 5,800 rpm -- hardly significant. BTW -- the A6 is turning around 5,100 at 186.
That's odd as at 176 mine was still pulling fine. But if yours was slower ... I'll except that.
Chevy is the claimer, not me, argue with them. Their ads specify the Z51 6 spd manual at 186 MPH. Posts in this Forum over a year ago said the .71 5th gear ratio of the Z51 was picked only to reach the top speed of 186 MPH. The HP/TQ combo at 5755 RPM in the Z51 is just enough to overcome air resistance at 186 MPH where the standard 5th gear ratio of .74 at 5899 RPM at 186 MPH can't be reached.
(Blue line is coupe, purple line is Z51)
