OBD2 Error Codes
Old 08-01-2006, 06:32 AM
mosty
Cruising
mosty's Avatar
Default OBD2 Error Codes
Hello Everybody,
can anyone tell me what this errorcodes are?
It comes from a C6:
Read Stored DTC: B20:4
Read Stored DTC: P3040
Read Stored DTC: C1014
Read Stored DTC: P11:0
Read Stored DTC: P1550
Read Pending DTC: P0001
Read Pending DTC: P20:4
Read Pending DTC: C3080
Read Pending DTC: P0003
Read Pending DTC: C21:0
Read Pending DTC: P0500
Read Pending DTC: C2013
Read Pending DTC: C1012
Read Pending DTC: ER410
Thanks for all...
Old 08-01-2006, 06:49 AM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Have a look at this list. It will get you started identifying those codes.
Courtesy of David Farmer:
http://www.davidfarmerracing.com/C6-DTC.PDF
That thread can be found courtesy of the C6 Frequently asked question file which is a sticky thread at the top of this page, here:
http://forums.corvetteforum.com/showthread.php?t=927981
You can search the FAQ using the Cntrl + F key to find key words.
F.Y.I., most of those do not appear to be valid C6 error codes.
Paul
Old 08-01-2006, 07:56 AM
mosty
Cruising
mosty's Avatar
Thanks for the Help, but the most of the Codes i can not find....
Old 08-01-2006, 08:11 AM
talon90
talon90's Avatar
NCM Ambassador
Sorry that you are not satisfied with the assistance ( ) but as I indicated in my original reply above, most of the codes that you list do not appear to be valid codes for the C6 (the codes with the : in them especially). That list is a complete list and I was not able to find your codes in my service manual either. Not sure what else to do to help. Perhaps you should try posting your question in the Tech section.
Old 08-01-2006, 08:23 AM
PappyTinker
PappyTinker's Avatar
Location: Life ain't no dress rehearsal, are you gonna wait to get your toys til AFTER you have a heart attack?
The only one I can find is;
P0500 Vehicle Speed Sensor Malfunction
Old 08-01-2006, 01:21 PM
mosty
Cruising
mosty's Avatar
Hi Paul, i have now the right error codes, looks like something is about the O2Sensors:
P0030
P0030
P0036
P0050
P0056
P0135
P0141
P0155
P0161
and the engine lamp is on.
Old 08-01-2006, 01:44 PM
VET4LES
VET4LES's Avatar
P0030
P0030
P0036
P0050
P0056
P0135
P0141
P0155
P0161
All of these are HO2S Heater Control Bank 1 and 2 Sensor 1 and 2 are related. Have you done some MOD's lately?
Old 08-01-2006, 02:08 PM
mosty
Cruising
mosty's Avatar
Originally Posted by VET4LES
All of these are HO2S Heater Control Bank 1 and 2 Sensor 1 and 2 related. Have you done some MOD's lately?
I have some Headers on but i changed back to original, since them these codes here any suggestions?
Old 08-01-2006, 03:22 PM
VET4LES
VET4LES's Avatar
Did you erase the codes? If not you could try that. How long ago did you remove the headers and why? Are all of the wires connected to the O2 sensors?
Old 08-02-2006, 03:10 AM
mosty
Cruising
mosty's Avatar
I order new headers from my Corvette Dealer, it was headers from Melrose Motorsports and first he say it is no problem with warranty, and some days later he says no warranty when i use them so i changed back to normal and wait up to the end of the warranty.
The wires are all connected, i also look at the OBD system and the O2 Senors are working. I did erase the Codes but they come again. Today no more codes coming until now. I hope this will not come again....
Old 08-02-2006, 03:42 PM
VET4LES
VET4LES's Avatar
Maybe they will cycle off after several start and shut off cycles.
Old 08-03-2006, 03:13 AM
mosty
Cruising
mosty's Avatar
No they come again........
Old 08-03-2006, 05:16 AM
boomer 33
boomer 33's Avatar
How do you pull codes on an 07 c6? CAn you do it like the c5?
Old 08-03-2006, 06:41 AM
mosty
Cruising
mosty's Avatar
No not that i know, i use a OBD Interface with Software, look here:
http://www.obd-2.com/
And i use this Software:
http://www.scantool.net/?mode=displa...y=ScanTool.net
To OBD2 Error Codes
Quick Reply: OBD2 Error Codes
