Wheel,tire,rotor weight comparisons
Old 12-04-2006, 10:47 PM
Rickmd
Rickmd's Avatar
Default Wheel,tire,rotor weight comparisons
For what its worth, here are the factory to after market weights of my wheel-tire-rotor combinations.
Front: 245-40 18x81/2 48 1/2 lbs plus Z51 rotor 22 lbs = 70 1/2 total lbs. Replaced with 275-35 18x10 CCW/Mich Pilot Sport 52 Lbs plus Eradisport Plus2 rotors 17 lbs = 69 lbs total. Reduced 1 lb, gained 1 1/2of wheel and tire. Not to bad.
Rear: 285-35 19x10 58 lbs plus Z51 rotor 21 1/2 lbs = 79 1/2 lbs total. Replaced with 345-30 19/13 CCW/Mich Pilot Sport 62 lbs plus 14" Eradisport Plus2 rotor 19 lbs = 81 lbs total. Gain of 1 1/2 lbs but wheel/tire combo increased 3 inches plus larger rear rotor. A fair trade!
Old 12-04-2006, 11:05 PM
Steve Theodore
Steve Theodore's Avatar
Thanks...always nice to see real weights posted up for comparison.
Old 12-05-2006, 03:28 PM
Van Steel
Premium Supporting Vendor
Van Steel's Avatar
Default weights
Were the numbers you used for what you took off worn verse what you put on new??? it's nice to see your attention to rotating weights... You will be amazed when the numbers are lighter...
PL
Old 12-05-2006, 04:01 PM
excessive81
excessive81's Avatar
wow that good to knpow....guess i need new rotors to balnce out the wheels. i figured going from run flats to normal would help more
Old 12-05-2006, 04:12 PM
xstang
xstang's Avatar
Thanks for that... I'm considering swapping rotors and I was curious to the actual weight savings...
Old 12-05-2006, 07:18 PM
Rickmd
Rickmd's Avatar
PL
The wheels and tires were brand new.
To Wheel,tire,rotor weight comparisons
Quick Reply: Wheel,tire,rotor weight comparisons
