Compression Ratio w/ 70cc AFRs - ?
What is the formula for calculating the compression ratio with the larger CC heads?
I hope this allows for more boost.
http://www.race-cars.net/calculators...alculator.html
Stock heads are 64cc I'm pretty sure, so those heads will lower compression all other things left untouched.
I found some web sites that do the calculations for you.
70cc 10.17:1
72cc 9.95:1
76cc 9.53:1
It seems that bumping the cc is a good way to lower compression and allow for more boost.
70cc 10.17:1
72cc 9.95:1
76cc 9.53:1
as you can see your dropping about one tenth of a point for each cc you increase. the stock ls6 head is 65 cc. everything else the same, gasket etc you should be right around 10.4
