Rolf Persson electrical problem 90 vette
I are having problem solving som problems 1 no ses light2 scanner wont read any codes the sir light stays on i chaged the ccm and ecm and the interior light does not work whit the door i will be greatful for any sugestions
Have you checked the interior dimmer switch on the dashboard to the left of the steering wheel because it maybe turned on. This is a guess since I am struggling with you English.
I am assuming that English is not your first language based on your post.
thanks for answer my first language is swedish i fund the problem with the interior light it was the relay but i still strugel with the other problems i do not have any service engine light and scan tool will not read anything i will try to clear the derm memory and se if that will turn the sir light off
