Factory LS2 cam specs
Here are the specs off of our Cam Doctor. It's probably way more than you would want, but it's never bad to have too much info.
CLOSE AREA
Lobe I1 ----- ------ -----------
Centerline 115.93 ATDC 0.006 261.91 9.17 BTDC 72.74
ABDC 22.02
.050 Lift C/L 117.24 ATDC 0.020 232.41 2.52 ATDC 54.93
ABDC 21.83
Runout 0.00020 0.050 203.72 15.38 ATDC 39.10
ABDC 21.32
Peak Open Acc. 0.000413 0.100 173.40 29.75 ATDC 23.15
ABDC 20.15
Peak Nose Acc. -0.000285 0.150 147.27 42.51 ATDC 9.78
ABDC 18.46
Peak Close Acc. 0.000354 0.200 119.87 56.13 ATDC 4.00
BBDC 16.21
Lift @ TDC 0.0159 0.250 86.45 72.72 ATDC 20.82
BBDC 12.18
Lobe Separation 115.9 0.300 29.58 101.12 ATDC 49.30
BBDC 4.20
0.30669 --- PEAK CAM LIFT ---
0.52137 --- PEAK VALVE LIFT ---
LIFT DUR. OPEN
CLOSE AREA
Lobe E1 ----- ------ -----------
Centerline 115.93 BTDC 0.006 270.71 66.26 BBDC 24.45
ATDC 23.03
.050 Lift C/L 114.71 BTDC 0.020 241.86 54.53 BBDC 7.33
ATDC 22.86
Runout 0.00030 0.050 212.90 41.16 BBDC 8.26
BTDC 22.37
Peak Open Acc. 0.000384 0.100 181.67 26.20 BBDC 24.53
BTDC 21.22
Peak Nose Acc. -0.000256 0.150 154.43 12.84 BBDC 38.42
BTDC 19.52
Peak Close Acc. 0.000325 0.200 125.49 1.49 ABDC 53.03
BTDC 16.98
Lift @ TDC 0.0318 0.250 90.49 18.93 ABDC 70.58
BTDC 13.02
Lobe Separation 115.9 0.300 31.38 48.39 ABDC 100.24
BTDC 4.78
0.30694 --- PEAK CAM LIFT ---
0.52180 --- PEAK VALVE LIFT ---
CLOSE AREA
ABDC 22.02
ABDC 21.83
ABDC 21.32
ABDC 20.15
ABDC 18.46
BBDC 16.21
BBDC 12.18
BBDC 4.20
LIFT DUR. OPEN
CLOSE AREA
ATDC 23.03
ATDC 22.86
BTDC 22.37
BTDC 21.22
BTDC 19.52
BTDC 16.98
BTDC 13.02
BTDC 4.78
