DIY: Z06 Muffler Install with Functional Butterflies
#41
Wouldnt it be fairly easy to use an RPM window switch like a nitrous kit uses and have it send to an electronic actuator switch that opens during certain RPM ranges, or maybe set to a full throttle activation switch that it only opens at full throttle? Or even just on an electronic toggle switch. Then you wouldnt have to have any vacuum at all. Just some ideas that might be cheaper.
#42
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
The butterflies are closed with engine vacuum. The solenoid then vents the butterflies when no voltage is present to open the valves.
Voltage at vacuum solenoid = closed butterflies
No voltage at vacuum solenoid = open butterflies
#43
There is no way to make them close without the vacuum lines; correct?
#45
Could you simply install a electrical solenoid in place of the vaccum unit? This would like the ones used on eletric cutouts. This would only need a electrical conection. That was a great write and a lot of work to share it. Was just thinking when I saw the solenoids mounted underneath.
#46
The '08 NPP mufflers are now available (p/n 15879289 & 15879288), so it would be a much easier install using these as they have 2.5" pipes (ie. just bolt in a C6)
Vacuum requirements are still the same.
I just installed these on my 07 C6 Z51. Best thing I have done, next to the headers. Sound great (no drone at cruise, excellent noises under load), plus they look good! Gold star to GM for these!!
#47
#48
Did you also install all the vacuums?
#49
No. There is only one solenoid. The pieces on the mufflers are vacuum actuators. They don't have a motor inside and are strictly operated off vacuum. To use electricity only you would have to install electric actuators. It would be a lot cheaper to just buy electric cutouts.
#51
#52
CI 3-5-6-7-8 Veteran
Awesome job I wish there was something similar for the C5. I bet you could cut the rear tub in the C5, make room for these mufflers, and run the same setup.
You'd need to be able to weld to instal new exahust hangers, but it'd be pretty cool.
#53
Former Vendor
I don't think this has been covered in this thread, but if you had a C6 Z06 and wanted the valves kept CLOSED at all rpms to keep noise down at a noise restricted track:
a) can that be done?
b) would it cause any problems?
My original thread is here: http://forums.corvetteforum.com/show...post1561771150
#55
#56
St. Jude Donor '13
Full closed mode is the mose difficult to do of the three modes possible.
Its easy on a C6 retrofitted car and a little more difficult on a stock NPP or Z06. But definately not impossible!
When you take power away from the solenoid the Butterflies go full open.
When you apply power to the stock gm exhaust controller via the exhaust fuse the Butterflies open at whatever rpm gm programmed them to.
To do full closed you need to wire around the stock GM exhaust flow controller so that they are not removing power from the solenoid.
For people who have retrofitted the NPP or Z06 mufflers its easy to do full closed as there is no GM exhaust controller in the car. And they have had to run the signal wire to the vacuum solenoid already to make the system open and close.
For people who have a NPP or Z06 with stock Bi-Mode Exhaust and want full closed, they will need to bypass the GM controller by running a wire from the vacuum solenoid to the Fuse panel in the passenger footwell and then sendnig a signal from an aftermarket controller.
If you use my NPP / Z06 Exhaust Commander to control the rpm open mode and full open mode, and run the wire from the fuse panel area and hook the exhaust signal wire from the NPP / Z06 Exhaust Commander to the vacuum solenoid, you can get full closed mode by unhooking the RPM signal connector on the NPP / Z06 Exhaust Commander. Thus applying power all the time for full closed, and removing power for full open.
If anyone needs any additional info, let me know!
Ben
Ben
#57
With the Add-a-fuse oriented as shown, I believe that the circuit is essentially double fused with the 10A fuses and Add-A-Fuse (RH side of slot is hot - feeding power to switch and solenoid thru both 10A fuses)....no arm this way, just redundant.
Us mechanicals have to look out for one another considering we slept thru all that imaginary # stuff....
Look at the online instructons for the controllers and you'll see that they are opposite (add-a-circuit orineted with added circuit power wire exiting towards driver's side)..
#58
#60
Former Vendor
Ben
Ben
I am delighted because I was having difficulty getting my LPE Z06 on to lots of UK circuits due to noise restrictions, but now I can COMMAND the exhaust valve to stay closed at all rpms when required.
A much more elegant and high tech solution than bolting on some Supertrapps or other bolt-on cans.
