NPP / Z06 Exhaust Commander is HERE! The FIRST RPM adjustable Exhaust Controller!
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
The NPP / Z06 Exhaust Commander is HERE, Click Here to go to the WEBSITE!!
So You want more than just a Basic On / Off switch for your Bi-Mode Exhuast?
The NPP / Z06 Exhaust Commander is the First RPM adjustable Bi-Mode exhaust controller for the Corvette C6 and C6 Z06.
With the NPP / Z06 Exhaust Commander kit, you take full Command of your Bi-Mode exhaust system by choosing what RPM the butterfly valves open at, as well as the ability to choose a Full Open mode.
You select between Full Open mode and RPM Opening mode via the supplied wireless remotes.
You select the RPM at which the muffler butterflies open by setting the dip switches on the RPM Command unit.
YOU take Full Command of Your Bi-Mode Exhaust!
Do you want the muffler butterfly valves to open at 1800 RPM so that the mufflers remain open the longest time possible, while eliminating the "Drone Zone" Rpms? NPP / Z06 Exhaust Commander is for YOU!
Do you want the butterfly valves to open just a little sooner? Set the NPP / Z06 Exhaust Commander to open at 2600 RPM's. You decide when you want the butterfly valves to open, not GM's engineers!
With the NPP / Z06 Exhaust Commander, You select the RPM at which the butterfly valves open. The RPM choices at which the valves open are: 1800, 2000, 2200, 2400, 2600, 2800, 3000, and 3200 RPM on the standard unit. (Custom Rpm settings are available)
You also can choose the Full Open mode for those times where you want it Loud all the time! And can switch back on forth between the two modes instantly with the wireless remote.
The NPP / Z06 Exhaust Commander will NOT Drain your battery when the car is Off, and always starts in the Quiet Rpm open mode like a stock car, only with a lower rpm opening point!
This Product works on any 08 NPP Bi-Mode Exhaust system or Z06 Bi-Mode Exhaust system.
It also gives full control to C6 cars that have retrofitted the NPP / Z06 Mufflers and want a RPM opening mode!
It allows users who have retrofitted Z06 or NPP mufflers to a C6 to have a user selectable RPM opening mode, as well as the Full Open mode. Thus making the retrofitted system work similarly to a Factory system, only Better as the user Commands the valves to open at the user selected RPM. The retrofittted systems do need to have the vacuum control solenoid in place for the NPP / Z06 Exhaust Commander to have the ability to control the Butterfly Valves.
NPP / Z06 Exhaust Commander uses the Tachometer signal and a RPM control unit to tell the Butterfly Valves to open.
The system is 95% plug and Play. Full, Detailed Installation instructions with pictures included.
Finding the Tachomoter signal wire is the only part of the install that is not a direct plug and play. With full detailed instructions on how to find the Tachometer signal wire that is just above the fuse panel in the passenger footwell area, and a supplied bed of nails test clip, the process of finding and testing the tachometer signal wire is easily accomplished by anyone. You can also tap the tachometer signal wire directly behind the tachometer gauge itself if you choose.
Why let Gm's engineers control your exhaust?
Order yourself a NPP / Z06 Exhaust Commander and take Full Command of your Exhaust Today !
Initial Offering Sale Price is $175 for the NPP / Z06 Exhaust Commander Wireless kit, Shipping is Free in the 48 states!
A NPP / Z06 Exhaust Commander RPM Control ONLY KIT is available that does not have the wireless switch and only controls the rpm at which the butterflies open. With the RPM only kit you can add the RPM control to a stock npp or z06 or a retrofitted car without the on/off wireless switch or ful open mode. You could also add the RPM control capability to a wireless or wired switch that you already have. The RPM ONLY NPP / Z06 Exhaust Commander kit is being offered at $100 shipped.
Feel Free to drop me a PM with any questions you may have!
This product carries a 180 day warranty from the date of purchase. There are no refunds or exchanges on this product, this product will only be repaired or replaced with the same product in the event of a warranty claim.
St. Jude Donor '13
Thanks to All that have purchased a NPP / Z06 Exhaust Commander!
You have chosen the Most Advanced Bi-Mode Exhaust Controller available!
When you get them all installed be sure to stop back in and let me know how you like them!
If you have any questions or suggestions, Let me know!
Ben
Ben
