2007 C6 Oil Change - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace
2007 C6 Oil Change
Old 11-22-2007, 08:05 PM   #1
gweissgerber
Junior Member
gweissgerber's Avatar
Default 2007 C6 Oil Change
I'd like to know what the experts in this community think about the computer suggested oil change intervals. I am an old fart that has dealt with oil changes by mileage. I think that the idea is cool, but it's hard to change old habits. Also, I was told by my dealer that if i used Mobil 1 I didn't need to change the oil for 5,00 miles. That seems a bit long to me, but at $70 per change for Mobil-1 I don't want to do it more then is conservatively prudent. Your thoughts?
George W
gweissgerber is offline   Reply With Quote
Old 11-22-2007, 09:33 PM   #2
mneblett
CF Senior Member
Cruise-In VIII Veteran
mneblett's Avatar
Quote:
George W
I, too, come from the old school -- but I've learned to trust the computer. I haven't gone back to do the search, but there's a thread from an ex-GM guy that worked on the development of GM's oil life algorithms. I'm a born skeptic (and former engineer), but I read enough to be convinced; coupled with nothing but good reports from oil monitoring services, I now rely on the DIC oil life % report.
mneblett is offline   Reply With Quote
Old 11-22-2007, 09:34 PM   #3
pewter99
Auctioneer Administrator
Support Corvetteforum!
Tampa Regional Coordinator
C6 of Month Finalist 2015
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
pewter99's Avatar
The first time in your life that listening to your DIC won't get you in trouble
pewter99 is offline   Reply With Quote
Old 11-22-2007, 09:50 PM   #4
K9KUZ
CF Senior Member
K9KUZ's Avatar
I doubt if you would get a 100,000 mile warranty if Chevy thought the DIC was wrong.
K9KUZ is offline   Reply With Quote
Old 11-22-2007, 10:49 PM   #5
Tx07BlackZ51
CF Senior Member
Tx07BlackZ51's Avatar
Quote:
Tx07BlackZ51 is offline   Reply With Quote
Old 11-22-2007, 11:57 PM   #6
Silver05GTO
CF Senior Member
Silver05GTO's Avatar
Yes "learn" to trust it. I too was a skeptic but as others have said reading up and hearing from experts have conviced me to follow the oil life percentage.
While at Carlisle a tech described a customers C5 vette that always followed the percentage, that LS1 had over 200,000 miles on it, they decided to tear into the motor for the heck of it, they found no problems or enhanced engine wear, they described it as looking "like new" inside.
Silver05GTO is offline   Reply With Quote
Old 11-23-2007, 12:16 AM   #7
1yy07vette
CF Senior Member
good thread
1yy07vette is offline   Reply With Quote
Old 11-23-2007, 02:52 AM   #8
CessnaDriver
CF Senior Member
CessnaDriver's Avatar
Warms my heart to see some more folks coming around on this.
Mobil 1 Test Results
http://neptune.spacebears.com/cars/stories/mobil1.html
"what have we learned so far? Here are a few points to ponder, based on our experience with the Mobil 1 phase.
Getting just one oil analysis only tells a tiny piece of the picture. It essentially would serve only as a pass/fail mechanism; without a trend to monitor, the most interesting parts of the analysis would be impossible to see.
Total base number is a moving target. There are multiple methods for testing it, which makes comparisons between laboratories worthless, and none of the methods have repeatability rates worth getting excited about. While TBN is worth considering as part of the larger picture, as a singular measure it is too flawed to rely on.
Engine wear actually decreases as oil ages. This has also been substantiated in testing conducted by Ford Motor Co. and ConocoPhillips, and reported in SAE Technical Paper 2003-01-3119. What this means is that compulsive oil changers are actually causing more engine wear than the people who let their engine's oil get some age on it.
Topping up the crankcase is a critical component of extended oil change intervals, and frequent filter changes are most likely the key to extreme-length intervals. The cumulative effect of even minor top-ups, let alone a filter change, substantially increases the longevity of the oil.
Based on the results we've got here, we'd recommend 8,000 miles between oil changes on an engine that uses no oil at all, perhaps 10,000 miles on an engine that uses some oil, and 15,000 miles or beyond with a filter change every 5,000 miles. This, of course, isn't any kind of guarantee, and you must evaluate for yourself what your engine requires. One thing we're pretty sure about though: 3,000-mile intervals is a huge waste of resources."
GM Oil Life System & Simplified Maintenance
Frequently Asked Questions
http://www.gm.com/corporate/responsi..._qa_040104.jsp
GM engineers have been studying oil life for decades and they've learned that oil tends to degrade in a predictable pattern.
GM Engineer States that Oil Change Intervals Average 8,500 Miles with Oil Life Monitors...........
http://www.performancemotoroil.com/G..._Monitors.html
Typical drain intervals with General Motors’ Oil Life System, the onboard computer algorithm that tells drivers when it’s time to change their motor oil, are 8,500 miles, versus 5,000 for GM’s competitors, a GM executive told last week’s World Tribology Congress. Drain intervals over 30,000 miles are achievable with minor engine modifications and appropriate oil quality.
“We cannot say exactly when it will happen, but drain intervals will be lengthened,” James A. Spearot, director of GM’s Chemical & Environmental Sciences Laboratory in Warren, Mich
Personal test done by a BMW owner with data sheet...
How often do you change your oil? Maybe too often... | ted serbinski
http://tedserbinski.com/2006/04/03/h...aybe_too_often
"The verdict, for those who don’t care to look at all those numbers: After 15,600 of my abuse, there was nothing wrong with the oil."
NY Taxi experiment........
Consumer Reports Article
The surprising truth about motor oils
July 1996, pp 10-13
http://www.xs11.com/stories/croil96.htm
On the basis of our test results, we think that the commonly recommended 3,000-mile oil-change interval is conservative. For "normal" service, 7,500-mile intervals (or the recommendation in your owner's manual) should be fine.
CessnaDriver is offline   Reply With Quote
Old 11-23-2007, 09:54 AM   #9
gweissgerber
Junior Member
Default wow!
Thamks for all the good imformation
George
Old 11-23-2007, 12:19 PM   #10
LMB-C6
CF Senior Member
LMB-C6's Avatar
I agree about following the DIC change interval, but there's one exception. Some of us don't put a lot of miles on the car, and I think it's a bad idea to store it with old oil - so I change it before it gets put away regardless of what the oil life % tells me.
LMB-C6 is offline   Reply With Quote
Old 11-23-2007, 12:32 PM   #11
oldmansan
CF Senior Member
St. Jude Donor '09
oldmansan's Avatar
I can't even touch that. I am almost to the magic 500 mile mark so this post's timing is perfect. Thanks.
San
oldmansan is offline   Reply With Quote
Old 11-23-2007, 03:33 PM   #12
CessnaDriver
CF Senior Member
Quote:
The manual states to do it at a minimum once a year regardless of what the DIC says.
Old 11-23-2007, 04:25 PM   #13
jimmie jam
CF Senior Member
jimmie jam's Avatar
i'm old school all the way, you typically have to lock me down for some change. i was taught in the 60's that you change the oil/filter every 2,500/3000 by my father. i did this without question for decades, believe me. HOWEVER, about 5 years ago i saw the light about this stuff. i have always changed my own oil and now know that with todays oil (reg. or syn.) and filter technology it is a waist of time and money to do it before 5-6,000 miles at the least. i call frequent changes "false piece of mind" but that's just me. the C6 is every 12 months due to lack of use. my avalanche and CTS is dic oil change all the way. take me down to 20-30% just for giggles and i'm ready @ 8-10,000 miles...no sweat. currently the CTS reads 78% and there are 2,200 miles on the oil. i'm going to change it in another 800 miles???? dream on!
jimmie jam is offline   Reply With Quote
Old 11-23-2007, 04:38 PM   #14
carpe dm
CF Senior Member
carpe dm's Avatar
There is NO reason top change your synthetic oil more often than the DIC indicates. However, I must admit that I still do a very conservative 6K or 6 Month schedule.
carpe dm is offline   Reply With Quote
Old 11-24-2007, 02:46 AM   #15
C6roadster
CF Senior Member
C6roadster's Avatar
Default Flip Question for you...
At what percentage reading on the DIC should the oil be changed then? 50%? 40%? 25%? 20%? or one year, whichever comes first. But still, WHAT IS THE CORRECT PERCENTAGE NUMBER TO GO BY? Does anybody know and why?
C6roadster is offline   Reply With Quote
Old 11-24-2007, 04:24 AM   #16
wjcook1
CF Senior Member
wjcook1's Avatar
I believe the check engine light will come on to reminder you to change the oil if you need all this help. Pick a number you feel comfortable with say once a year or when the % gets to say 20% whatever, it is not that much of a difference. I do it on the build date of my vette sort of a birth day present and it is a date I will keep track of untill the next new one.
wjcook1 is offline   Reply With Quote
Old 11-24-2007, 07:58 AM   #17
jimmie jam
CF Senior Member
jimmie jam's Avatar
Quote:
between 10 and 0%. i believe your owners manual states this.
Old 11-24-2007, 09:09 AM   #18
NIGHTSTALKER
CF Senior Member
NIGHTSTALKER's Avatar
Call me hard-headed, but my oil has always, and will always be changed at 2500-3000 miles. I just look at it like going above and beyond
NIGHTSTALKER is offline   Reply With Quote
Old 11-24-2007, 10:34 AM   #19
LMB-C6
CF Senior Member
LMB-C6's Avatar
It's kind of like using your gas gauge. You don't want to wait until it reads '0', but it's not necessary to fill up when you are at half full. Same goes for the oil change, no need to do it when it says '50%', but if you are getting to the single digits you should get the thing serviced, unless it's been a year in which case you change it regardless.
Old 11-24-2007, 12:36 PM   #20
JPchevy
CF Senior Member
JPchevy's Avatar
My personal belief is that if you don't drive much (less than 10k/yr), regardless if it's synthetic, every 6 months is for good measure.
JPchevy is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 2007 C6 Oil Change
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Engine oil C6CorvetteGuy C6 Tech/Performance 5 07-23-2010 07:24 AM
    1st Oil Change? Jeffrey's Vette C6 Corvette General Discussion 20 10-02-2009 10:37 PM
    5w-30 mobil 1 too light??? RACERB C4 General Discussion 10 06-22-2005 10:49 PM
    who has the best deal on oil filters? White98Corvette C5 Scan & Tune 1 02-06-2003 02:52 PM
    Tags
    07, 2007, c6, change, changing, chevrolet, corvette, motor, oil, recommendation, type
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
