z51 suspension to base c6
8th Gear
i'm considering the purchase of an 06 c6 z51, however the suspension is too stiff for my use. this may go against some die-hard vette fans, but is it possible to change the suspension from a z51 to the base corvette? if so, where can i get the oem suspension at a decent price. thanks...
GM parts house.com gene culley will take care of you, I bought the base model and added Z51 sway bars and Bilstein shocks{sports} shock warehouse.com IT IS PERFECT NOW!!!
I have my new stock sways. I'll let you have them cheap.
Send me an e-mail sjjohnson@securenet.net or PM if you prefer.
Spring rates in the rear are almost identical, Rates in the front, on the Z51 are a little higher, but the shocks should control that nicely. Z51 owners who have made only a shock change have been very pleased..
I would really suggest to go with the z51 then just change the shocks.
Reason is I had a base suspension and upgraded to Z06 and z51 springs but kept the base shocks absorbers.
Very very confortable ride.
good luck!
good luck!
