C6 1/4 Mile Performance Challenge
#6861
Internal LS3 Grand Sport 1/8th mile
Category : LS3 Internal Grand Sport
4. 2011 Grand Sport
5. TR6060
6. Stock Suspension
7. Stock Performance options (as in optional gears with the automatic, & etc.)
8. Weld RTS Drag Pack w/ MT 315/35-17
9. Modifications: Heads ported by TEA, milled .040 and touched up by Tooley, BTR Stage 4 Cam, stock LS3 Intake, Vararam CAI, 160* Thermostat, Pfadt 1 7/8" Headers with 3" Corsa Sport out the back, McCleod RXT clutch, Tick Master
10. Dyno numbers: None Yet
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc. No sway bar (not sure if that even helps) front tires @ 45 psi, rears @ 15 psi. Leaving around 5 to 5.5K rpms and abusing the clutch to launch. Still learning how to drive..
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Music City Raceway
___ 9/19/14- 72* and DA was around 2300' iirc
___ 60'.............1.5870
___ 330'...........4.5470
___ 660'...........7.014
___ 660’ mph....102.27
___ 1000'.........N/A
___ 1320'.........N/A
___ 1320’ mph…N/A
Copy of Time Slip Below
4. 2011 Grand Sport
5. TR6060
6. Stock Suspension
___ 1320’ mph…N/A
#6862
4. 2011 Grand Sport
5. TR6060
6. Stock Suspension
___ 1320’ mph…N/A
http://youtu.be/qRYGDLTtFC0
4. 2011 Grand Sport
5. TR6060
6. Stock Suspension
___ 1320’ mph…N/A
#6863
Anyone know of any rentals at Atco coming up that I might be able to join in on? I'm going to one on the 10th next month but I'd be up for any others whether it's before or after.
#6865
Category:LS3 bolt on
4. Year Corvette 2008
5. Type of Trans A6
6. Type of Suspension z51
8. Tires utilized: MT 275/40/17
9. Mods: kooks 1 7/8, CAI, DR, tune & more
10. Dyno numbers if you have them
11. 20psi in tires, left from 2000 RPM
___ Name of the Track Great Lakes Dragaway
___ Date of the pass & weather conditions 10/10/2014
___ 60'.............1.593
___ 330'...........4.636
___ 660'...........7.156
___ 660’ mph....97.74
___ 1000'..........9.318
___ 1320'..........11.144
___ 1320’ mph…123.49
5. Type of Trans A6
#6871
Updated Time
LS3 Internal Grand Sport 1/8th Mile
- 2011 Grand Sport
- TR6060
- Stock Suspension
- Stock Performance options (as in optional gears with the automatic, & etc.)
- Weld RTS Drag Pack w/ MT 315/35-17
- Modifications: Heads ported by TEA, milled .040 and touched up by Tooley, BTR Stage 4 Cam, stock LS3 Intake, Vararam CAI, 160* Thermostat, Pfadt 1 7/8" Headers with 3" Corsa Sport out the back, McCleod RXT clutch, Tick Master
- Dyno numbers: None Yet
- As much info you may want to add about the run, launch techniques, tire air pressure & etc. No sway bar (not sure if that even helps) front tires @ 45 psi, rears @ 17 psi. Bringing rpms up to around 5500 RPM's and coming out on clutch and putting it to the floor at the same time and trying to merge them as smoothly as possible.
- Typed in the post (as some time slips get deleted & etc after being posted)
___ 10/21/14- 59* and DA was around 700'
___ 60'.............1.5031
___ 330'...........4.4360
___ 660'...........6.8549
___ 660’ mph....104.37
___ 1320’ mph…N/A
- 2011 Grand Sport
- TR6060
- Stock Suspension
___ 1320’ mph…N/A
#6876
New or Improved times:
11.144 @ 123.49 JBrunoJSBC6
0.6894 @ 104.37 RMAC6
If your time has not been posted it is because you have not followed the requirements for posting your time. I need the entire time slip as well as a completed copy of the template included in your request as required on page one.
Showroom Stock LS2 (2005 -2007)
12.215 @ 115.45 - LS1LT1 - 06 A6 - (1278)
12.235 @ 115.58 - 06C6FVR - 06 M6 Z51 - (333)
12.290 @ 114.29 - Proney - 07 M6 - (4500)
12.314 @ 114.82 - CYA Vett - 05 M6 F55 - (675)
12.422 @ 113.90 - DrRichie - 05 M6 Z51
12.499 @ 114.90 - Jschindler - 05 M6 Z51
12.53x @ 113.00 - Wicked07C6 - 07 M6 Z51 - (914)
12.540 @ 113.59 - Tony 63 Vette - 06 A6 - (1510)
12.548 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1149)
12.56x @ 113.39 - Red Sleeper - 06 A6
12.56x @ 112.00 - Orange C6 - 05 A4 Z51 - (56)
12.650 @ 111.65 - Zippin Zee - 05 M6 Z51 - (48)
12.665 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1675)
12.693 @ 114.88 - Prankster - 06 M6 - (1621)
12.69x @ 112.32 - Silverlx - 06 A6 - (872)
12.703 @ 112.43 - Jelsis - 06 A6 Z51 - (452)
12.70x @ 113.00 - Blackmajik - 07 A6 - (1627)
12.71x @ 111.30 - Flyin05 - 05 M6 Z51
12.71x @ 111.00 - Demented - 05 A4 Z51
12.74x @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.756 @ 112.57 - C5Pilot - 07 A6 Z51 - (903)
12.757 @ 109.25 - Ponchorello - 05 A4 3.15 - (990)
12.795 @ 112.17 - Jchazr - 05 M6 Z51 - (447)
12.80x @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1668)
12.81x @ 112.83 - Vette-oholic - 05 M6 Z51 - (494)
12.817 @ 110.95 - SkyKing - 07 A6 F55 - (2480)
12.85x @ 114.53 - Mr Z51 - 06 M6 Z51
12.917 @ 111.67 - Brewcitygymratt - 06 A6 - (4578)
12.936 @ 111.40 - DiggyMoe - 07 M6 - (965)
12.97x @ 108.00 - Ginny C6 - 05 A4 F55 - (56)
12.98x @ 108.00 - Tampa Vet - 05 A4 3.15 - (119)
12.99x @ 111.70 - C64ME - 05 M6 Z51 - (329)
13.04x @ 109.15 - TMyers - 06 A6 - (528)
13.054 @ 113.31 - RDunn - 06 M6 - (982)
13.10x @ 108.70 - Rothchilds - 05 A4 F55 3.15
13.12x @ 110.40 - JDWK - 05 M6 Z51
13.25x @ 110.60 - C6 Matt - 05 M6 Z51 - (118)
13.267 @ 108.59 - Sfadchi - 06 A6 Z51 - (884)
13.26x @ 105.30 - Joeking - 05 A4 Z51 - (657)
13.30x @ 107.00 - Shurite44 - 06 A6 Z51 - (764)
13.35x @ 108.10 - Phatpharmd - 06 A6 - (591)
13.62x @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - 2013)
11.718 @ 119.94 - AndrewZPSU - 08 M6 - (2586)
11.806 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3478)
11.974 @ 116.98 - Proney - 08 M6 Z51, NPP - (4652)
12.058 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5051)
12.100 @ 115.19 - Odin - 09 A6 2.73 npp - (4325)
12.102 @ 117.60 - Dingrao - 08 A6 - (3561)
12.127 @ 116.59 - Pettvette - 08 A6 - (4278)
12.159 @ 115.59 - Old Goat - 09 A6 2.73 - (3708)
12.167 @ 117.15 - DarkOctane - 08 A6 NPP - (6310)
12.167 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2740)
12.186 @ 117.72 - Hardhattg - 08 M6 Z51 - (2686)
12.237 @ 112.86 - 940CACC - 08 A6 - (2871)
12.244 @ 117.83 - 74Vette - 08 M6 - (4617)
12.273 @ 117.32 - C6David - 08 A6 NPP - (6854)
12.305 @ 116.51 - JBrunoJC6 - 08 A6 NPP - (6722)
12.400 @ 116.36 - RandyDank23 - 08 A6 - (6059)
12.262 @ 115.22 - Oklahoma - 08 A6 - (3765)
12.276 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3247)
12.355 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2755)
12.357 @ 116.94 - TNorman - 08 A6 NPP - (4227)
12.408 @ 116.11 - XtremeChubbles - 08 A6 Z51 - (6589)
12.409 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2132)
12.419 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3185)
12.412 @ 115.38 - HOXXOH - 08 A6 F55 - (2478)
12.428 @ 116.67 - Pea-Jay - 08 A6 - (4448)
12.494 @ 115.54 - 1.8T - 08 M6 Z51 - (2310)
12.500 @ 115.53 - Shane Fap - 08 A6 - (6298)
12.514 @ 116.73 - SK360 - 08 A6 2.73 - (6283)
12.552 @ 114.70 - Larry R - 08 A6 2.73 - (4054)
12.600 @ 114.12 - Beefcake - 08 A6 - (2875)
12.658 @ 114.99 - PhillyLS1 - 09 M6 - (3151)
12.668 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2828)
12.689 @ 112.07 - Bfppt1 - 10 A6 - (5300)
12.747 @ 114.31 - Detoxx03 - 08 M6 NPP- (4057)
13.354 @ 110.78 - M453W - 09 A6 NPP- (5708)
13.428 @ 109.32 - Dan Wendling - 09 A6 NPP - (4032)
Showroom Stock LS3 Grand Sport (2010 - 2013)
12.319 @ 115.75 - Grand SportMan - 10 A6 - (5128)
12.463 @ 115.25 - Kuhnrod - 10 A6 - (6737)
12.559 @ 115.41 - Fastenuf - 11 A6 - (5269)
12.805 @ 113.33 - PhillyLS1 - 11 M6 NPP - (5085)
Showroom Stock LS7 Commemorative Edition 427 (2013)
11.720 @ 121.34 - Gxpz06 - 13 M6 - (6856)
________________________________
External Engine Modifications LS2 (Bolt-Ons)
10.626 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (3944)
10.788 @ 127.29 - LS1LT1 - 06 A6 - CAI, conv, fast, hdr, ptb, skinnies, tune, & more, DR - (5611)
10.936 @ 123.01 - Dicky - 06 A6 - CAI, conv, cutouts, fast, 3.42, hdr, & more tune, DR - (5485)
11.121 @ 124.49 - Teetheriot - 07 A6 - CAI, conv, fast, hdr,nc , Z06 muff, & more, tune, DR - (5869)
11.293 @ 122.24 - JMT1669 - 06 A6 - CAI, conv, cb, fast, 3.42, hdr, tune, DR - (4427)
11.295 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, conv, Pfast, hdr, no cats, tune, udp, DR - (5105)
11.342 @ 125.78 - Silvervette05 - 05 M6 – pfast/tb, gto skinnys, Z06 exhaust, tune, DR - (4422)
11.412 @ 119.27 - Devilish34 - 07 M6 - CAI, hdr, pfast, Z06 rear, tune, DR - (5536)
11.495 @ 121.77 - NastyS1K M6 – Cai, cb 3.90,pfast/tb, gto skinnys, tune, DR - (6669)
11.594 @ 117.15 - Cold6.2 - 05 A4 Z51 - CAI, conv, C5 rear, hdr, tune, DR - (6823)
11.650 @ 122.57 - Vade 46 - 07 M6 Z51 - CAI, hdr, tune, DR - (6723)
11.667 @ 118.76 - Its Stock - 06 M6 - CAI, hdr, udp, tune, DR - (4565)
11.747 @ 120.83 - Siffert - 07 A6 - CAI, cb, pfast, hdr, skinnies, tune, DR - (3982)
11.76x @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, 3.73, hdr, pi/tb, tune
11.775 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdr, pi/tb, tune - (2175)
11.792 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, tune, DR - (3225)
11.811 @ 118.76 - Joe G - 05 M6 Z51 - CAI, 3.90, hdr, pi, tune, DR - (1870)
11.879 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdr, pi, tune, DR - (3554)
11.87x @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdr, tune, DR - (835)
11.937 @ 115.77 - DMcRacer - 07 A6 Z51 - CAI, conv, Z06 exhaust, tune, DR - (5438)
11.94x @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdr - (525)
11.969 @ 118.98 - GMRULZ - 06 M6 Z51 - Bilstein shocks, cai, hdr, pi, tune, DR - (2159)
11.98x @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdr, pi/tb, tune, DR - (1966)
12.01x @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdr, pintake, tune, DR
12.03x @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdr
12.035 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdr, pi, tune, DR - (2273)
12.05x @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdr
12.052 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, 3.73, hdr, tune, DR - (4467)
12.084 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1445)
12.091 @ 114.63 - 68RSSS -05 A4 F55 - CAI, hdr, tune - (5066)
12.133 @ 116.10 - ParisTNdude - 06 A6 - CAI, cb, hdr, tune, DR - (6566)
12.136 @ 115.15 - Ben Diss - 07 M6 F55 - CAI, hdr, tune, Nitto Ivos - (1915)
12.154 @ 118.81 - Blf0005 - 06 M6 - CAI, cb, eco, hdr, pfast, tune, - (6582)
12.169 @ 116.82 - Gmkillr - 07 M6 Z51 - CAI, cb, fast, hdr, x pipe, tune, Dr - (6345)
12.174 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2185)
12.17x @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdr - (1224)
12.18x @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1818)
12.18x @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1820)
12.216 @ 115.98 - Mike Campbell - 06 A6 - CAI, DR - (5093)
12.219 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1319)
12.22x @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdr, tune - (1702)
12.26x @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdr, - (654)
12.26x @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdr, - (1114)
12.275 @ 115.94 - TNTC4Vette - 06 M6 Z51 - Bilstein shocks, cai, hdr, no cats, ptb, tune, Ps2 (5018)
12.278 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdr, Z06 Muff, tune - (4223)
12.285 @ 114.46 - AngeloC6 - 05 A4 F55 3.15 - CAI, cb, hdr, hankook tires, tune - (6300)
12.293 @ 118.41 - Ganador01 - 06 A6 F55 - CAI, Fast, hdr, tune (6263)
12.319 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdr, tune - (3625)
12.371 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdr - (64)
12.378 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, gears, hdr, tune - (364)
12.384 @ 116.78 - Goatdad - 06 A6 - CB - (6489)
12.391 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1469)
12.398 @ 115.47 - Berk4422 - 07 A6 - CAI, cb, hdr,ptb/I, tune - (6536)
12.42x @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdr, DR - (393)
12.483 @ 113.52 - EvlJake - 07 A6 - Cb, tune - (6051)
12.49x @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdr
12.49x @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdr, tune, DR - (1245)
12.50x @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (173)
12.50x @ 115.20 - Flooznie - 05 A4 - tune - (212)
12.515 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (488)
12.522 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdr, tune - (1598)
12.525 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdr, tune - (4408)
12.525 @ 112.09 - H-Z/28 - 06 M6 - Cb, no cats, tune - (6362)
12.534 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4572)
12.539 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.54x @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55x @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdr (839)
12.55x @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdr - (236)
12.590 @ 111.46 - 07Cobaltss/sc - 07 A6 F55 - CAI, cb, 3.42, RE11, tune - (5239)
12.59x @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdr, tune - (198)
12.59x @ 113.46 - Badassbu - 07 A6 - CAI - (1765)
12.60x @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (56)
12.627 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4521)
12.636 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63x @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65x @ 113.70 - Hitman99 - 06 A6 - CAI, hdr, tune
12.683 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2598)
12.68x @ 113.92 - Sditch - 05 A4 Z51 - CAI - (184)
12.712 @ 113.70 - C6Brian - 07 M6 - Tune - (1614)
12.770 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1265)
12.78x @ 112.50 - Dan-t - 06 A6 - Tune - (1175)
12.797 @ 115.58 - Sebaj - 05 M6 - CB, pi/tb, ud, Z06 exhaust, tune - (4435)
12.83x @ 111.00 - TMyers - 06 A6 - CAI, tune - (764)
12.88x @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.891 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdr, rockers, tune - (856)
12.89x @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(826)
12.900 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (537)
12.933 @ 110.64 - C6Vette - 06 M6 Z51 - CAI, cb, tune - (1202)
12.97x @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (222)
12.97x @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdr, tune - (693)
12.994 @ 111.25 - Parkev - 05 M6 Z51 - CB - (79)
13.30x @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1037) high alt
13.32x @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.953 @ 104.94 - Fright88 - 06 A6 - CB, hdr - (1679) high alt
External Engine Modifications LS3 (Bolt-Ons)
10.820 @ 125.82 - HOXXOH - 08 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, & more, DR - (4804)
10.888 @ 125.25 - 8850 - 08 A6 NPP 2.73 - CAI, conv, gto skinnies, hdr, udp, tune, DR - (6178)
10.987 @ 124.66 - Theofel - 08 A6 - CAI, cb, conv, 3.15, hdr, tune, & more DR - (4739)
11.112 @ 121.80 - Shane Fap - 08 A6 - CAI, hdr, tune, Z06 muff, Nittos - (6531)
11.144 @ 123.49 - JBrunoJSBC6 - 08 A6 Z51 – CAI, conv, hdr, tune, DR - (6870)
11.252 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, 3.73, hdr, pi, torco & meth inj, tune, DR - (3739)
11.266 @ 123.52 - JohnDaMan - 08 A6 - CAI, cb, conv, hdr, ptb, udp, tune, DR - (6785)
11.468 @ 119.14 - HPAvette - 08 A6 Z51 NPP 2.73 – CAI, conv, hdr, tune, DR - (5241)
11.519 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdr, ptb, Z06rear, tune, Invos - (3565)
11.537 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdr, ptb udp, tune, DR - (3735)
11.545 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx, hdr, tune, DR - (5146)
11.558 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdr, fast, 3.90, Et St - (3085)
11.56x @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdr, pi/tb, tune, DR - (2405)
11.562 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1848)
11.597 @ 124.34 - Cmorales515 - 08 M6 - CAI, hdr, ptb, tune, DR - (6762)
11.641 @ 122.03 - Chets LS3 - 08 M6 - CAI, hdr, ptb, skinnies, tune DR - (6772)
11.672 @ 118.89 - Justinjor - 08 M6 Z51 NPP - CAI, hdr, ptb, Removed fuse, DR - (5340)
11.688 @ 121.22 - Socalz06 - 08 A6 - CAI, hdr, DR - (2590)
11.706 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdr, tune - (2171)
11.726 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdr, tune, DR - (4421)
11.769 @ 120.88 - Dev1360 -09 M6 - CAI, cb, hdr, Nitto - (6704-16)
11.783 @ 121.67 - Nosferatu -10 M6 - Bilstein, hdr, tune, michelin - (6795)
11.796 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdr, tune, Ivos - (3785)
11.803 @ 121.56 - Cdaniel525 -08 M6 - CAI, hdr, no cats, Z06 exhaust, tune - (5437)
11.805 @ 121.34 - Cusvt - 08 A6 - Cb, hdr, propped shroud, DR - (6727)
11.881 @ 120.10 - SK360 - 08 A6 2.73 - hdr, Z06 muff tune, DR - (6720)
11.922 @ 118.74 - JAvery20 - 08 A6 NPP - CAI, tune BFG - (6721)
11.942 @ 119.44 - Corvet786C - 08 M6 - cb, hdr, 3.90, DR - (5854)
11.989 @ 120.04 - Rock n' Blue08 - 08 M6 - CAI, 3.90, hdr, Xpipe, Z06 muff - (2890)
11.992 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdr, tune - (4432)
11.994 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdr, tune, DRs - (2464)
11.995 @ 118.34 - Oklahoma - 08 A6 Z51 NPP 2.73 - Z06 exhaust & h pipe, P2s - (5718)
12.017 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdr, pi, ud, tune, DR - (4473)
12.016 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4598)
12.033 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdr, tune - (2525)
12.034 @ 119.35 - SeeFiveOhFun - 09 A6 - Con Dws Tires,cut shroud - (6551)
12.041 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3525)
12.058 @ 118.15 - DarthOctane - 08 A6 NPP - DR - (6327)
12.103 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4220)
12.118 @ 116.77 - MBB - 08 A6 Z51 NPP 2.73 - CAI, hdr, tune, nittos - (6488)
12.122 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3141)
12.144 @ 118.12 - Crisis - 09 A6 Z51 - Cai - (5234)
12.179 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3540)
12.231 @ 116.61 - Danieloneil01 - 08 M6 NPP - Hdr, NC, nittos - (5703)
12.267 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdr - (3927)
12.344 @ 118.40 - Airbuspilot - 08 M6 - CB - (3711)
12.410 @ 119.65 - PeterPan - 09 A6 2.73 - CAI, Tune ZR1 exhaust, 325 generals - (5902)
12.467 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdr, tune - (2906)
12.561 @ 114.70 - Gfish - 08 A6 Z51 NPP - CAI, tune - (5181)
12.509 @ 117.89 - AudaciousNick - 08 A6 Z51 - tires - (6814)
13.336 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2704)
External Engine Modifications Grand Sport (Bolt-Ons)
11.328 @ 125.03 - GrandSportMan -10 A6 - CAIHM, hdr, tune, DR - (6738)
11.944 @ 117.06 - GXPZ06 - 13 M6 - CAI hdr - (6853)
11.945 @ 118.55 - Agent White - 10 A6 NPP - CAI, hdr, tune - (4577)
12.185 @ 116.72 - EBF2K - 11 A6 NPP - CAI, hdr, tune, Ivos - (6398)
12.400 @ 115.45 - Thomasmoto - 11 A6 NPP - M2W switch - (6037)
Internal Engine Modifications LS2
10.157 @ 129.43 - Stanger383 - 05 A4 - CAI, conv, 3.42, H&C, hdr, ptb, Z06muff, tune, & more, DR - (6370)
10.163 @ 131.08 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, H&C, hdr, ptb, tune, & more, DR - (6493)
10.585 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast, 4.10, H&C, hdr, 100maf, tune, DR - (4430)
10.665 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, pfast, 4.10, hdr, H&C, tune, DR - (4296)
10.672 @ 128.31 - Justasheet - 05 A4 Z51 - CAI, cb, H&C, conv, pfast, 3.73, hdr, ptb, mh, Z06 Muff, tune, DR - (6510)
10.815 @ 128.07 - Joe G - 05 M6 Z51 - CAI, cb, cam, pfast, 4.10, hdrs, tune, DR - (5758)
10.821 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C, hdr, udp, tune, & more DR - (4579)
10.844 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, ported int/tb, udp, tune, DR - (4010)
10.87x @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, fast, 3.42, H&C, hdr, tune, DR
10.908 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdr, tune, DR - (3687)
10.951 @ 125.20 - Huggerorange73 - 06 A6 Z51 - Cam, cb, conv, fast, hdr, tune, udp, DR - (6843)
10.967 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdr, pi/tb, Z06 Muff, tune, DR - (4412)
11.002 @ 124.60 - EvlJake - 07 A6 - Cai, cam, conv, cb, hdr Ls3 heads, tune, udp, Dr - (6384)
11.013 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, conv, 3.15, H&C, hdr, tune, DR - (4611)
11.034 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdr, tune, DR - (3918)
11.192 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, DR - (4256)
11.199 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdr, L92/L76 combo, tune, Dr - (4075-76)
11.201 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdr, no muff, tune,DR - (2470)
11.23x @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, 4.10, hdr, udp, tune, Z06 tires - (1692)
11.243 @ 123.05 - Its Stock - 06 M6 - CAI, cam, hdr, udp, tune, DR - (5084)
11.247 @ 126.33 - Sebaj - 05 M6 - CB, Z06 Ex, H&C pi/tb, QA1 shocks, ud, Tune DR - (5934)
11.354 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, pfast, hdr, ptb, tune, DR - (3468)
11.390 @ 105.83 - Firefighter813x - 06 A6 Z51 - CAI, cb, 3.15, H&C, hdr, ptb, tune, , DR - (6630)
11.467 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdr, pi tune, DR - (2572)
11.49x @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast, hdr, udp, tune, DR - (1606)
11.514 @ 122.48 - GTkiller97 - 05 M6 Z51 - CAI, cam, fast, hdr, tune, DR - (5462)
11.52x @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdr, udp, tune, DR - (1905)
11.535 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdr, tune, DR - (867)
11.552 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdr, susp, tune, DR - (2757)
11.76x @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdr, tune, DR
11.790 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdr - (1817)
11.982 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdr, pi, udp, tune, DR - (1261)
11.994 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdr, fast udp, tune, DR - (4461)
12.31x @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdr, tune
12.410 @ 120.10 - Covert Guy - 05 M6 Z51 - cam, hdr, tune - (5700)
13.12x @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdr, tune
Internal Engine Modifications LS3
10.374 @ 133.59 - Matt@TuneTime - 08 M6 Z51- Cai, ewp, fast, hdr, H&C, 4.10, skinnies, tune, DR - (6378)
10.521 @ 127.96 - Bspc608 - 08 A4 Z51 NPP - CAI, H&C, conv, 3.42, hdr, udp, tune, DR - (6805)
10.611 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdr, mh, pi, tune, Z06 susp, tune, DR - (4609)
10.629 @ 126.77 - Shane Fap - 08 A6 - CAI, cam, conv, fast, hdr, tune, Z06 muff, Nittos - (6695)
10.633 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3640)
10.662 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, cai, 3.90, H &C, hdr, tune, DR - (3193)
10.673 @ 129.31 - Justinjor - 08 M6 Z51 NPP - CAI, cam, hdr, ptb/int, no fuse, skinnies, udp, tune, Zo6spring DR - (5904)
10.684 @ 126.58 - RV00GT - 08 A4 NPP - CAI, conv, H&C hdr 3.42, tune, DR - (6807)
10.739 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, pi/tb, udp, tune, DR - (3968)
10.793 @ 127.17 - Theofel - 08 A6 - CAI, cb, cam, conv, ewp, 3.15, hdr, tune, & more, DR - (5086)
10.974 @ 126.72 - LS3Chris - 08 M6 - CAI, cam, hdr, no muff, ptb, tune, DR - (6836)
10.996 @ 130.13 - AndrewZPSU -10 A6 NPP - CAI, cam, hdr, mhvj, ptb, tune, DR - (5571)
11.009 @ 128.08 - Dev1360 -09 M6 - CAI, cam cb, hdr, tune, DR - (6811)
11.032 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdr, tune, DR - (3896)
11.109 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdr, shaneTB, tune, DR - (4069)
11.143 @ 129.27 - AndrewZPSU - 08 M6 - CAI, cam, hdr, Z06 Exhaust, tune, DR - (4211)
11.179 @ 120.58 - Texasranger - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.328 @ 122.59 - Pitufina - 08 M6 - CAI, cam, hdr, ptb, z51npp, x pipe, tune, DR - (26820)
11.527 @ 125.42 - CBVette - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.946 @ 121.11 - Beefcake - 08 M6 - CAI, cam, hdr, udp, tune, DR - (5936)
Internal Engine Modifications Grand Sport
10.982 @ 124.94 - Amwells1 -12 M6 - CAI, cam, hdr, tune, DR - (6721)
11.551 @ 121.66 - Turboffr -10 A6 - CAI, cam, hdr, tune, - (6817)
Power Adders LS2 (supercharger, turbo, nitrous)
09.522 @ 144.71 - Tucan26 - 05 A4 - SC, alky, cam, conv, fast, hdr, RPM trans, tune, DR - (6729)
09.732 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, 3.42, hdr, RPM trans, tune, DR - (3258)
09.936 @ 136.88 - Tekhombre - 05 A4 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune, DR - (1153)
09.984 @ 135.44 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 4.10, tune, DR - (6363)
10.065 @ 141.65 - Jutskin - 05 A4 Z51 – SC Cam, coil overs, Flipdrive, Fast 3.42, Z06rear, & more, DR - (5901)
10.154 @ 139.08 - Devilish34 - 07 M6 - SC, hdr, meth, pintake, Z06 rear, tune, DR - (6701)
10.227 @ 143.70 - FactoryRaceCar - 05 A4 – TTurbo & alky, conv, 3.42, Z06rear, RPM Trans, tune, & more, DR - (5375)
10.420 @ 133.25 - RealCanuk - 07 A6 NPP - SC, gears, hdr, HFcats, tune, DR - (6311)
10.582 @ 135.54 - BMT03-mach1 - 05 M6 - N2O, CAI, cam,no cats, tune, DR (6565
10.665 @ 136.52 - Carlrx7 - 06 M6 Z51 – TTurbo & E85 pfat coil overs, tune, udp, DR - (5544)
10.680 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdr, DR - (4217)
10.724 @ 128.68 - Xdemonx - 06 M6 - SC, cam, hdr, tune, DR - (6796)
10.866 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdr, tune, DR - (476)
10.899 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (935)
10.905 @ 134.14 - Javw - 07 M6 – APS Twin Turbo, bilsteins, tune, DR - (6357)
10.960 @ 133.10 - NotStock22 - 06 A6 - SC, CAI, cb, hdr, tune, DR - (6821)
10.996 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, cam, cb, hdr, tune, DR - (3296)
11.074 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdr, DP, tune, DR - (3661)
11.094 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdr, DR - (2820)
11.18x @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.281 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdr, tune, DR - (1800)
11.285 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1648)
11.316 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdr, tune, DR - (1896)
11.370 @ 135.29 - Turboffr - 06 M6 Z51 - SC, cai, cam, fast hdr, meth, udp, tune, DR - (4516)
11.379 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdr, tune, DR - (589)
11.402 @ 121.47 - C6 Roller - 05 A4 - SC, hdr, tune, DR - (1768)
11.482 @ 120.98 - AngeloC6 - 05 A4 3.15 - SC, cb, tune - (6600)
Power Adders LS3 (supercharger, turbo, nitrous)
09.556 @ 144.52 - Gsbowman - 08 A6 - SC, cam, conv, 3.42, hdr, Z06 muff, & more, tune, DR - (5347)
09.759 @ 139.83 - Silver Bullet C6 - 08 A6 - SC, alky, cam, cb, hdr, pi/tb, tune, DR - (4986)
10.034 @ 134.38 - Theofel - 08 A6 - SC, cam, cb, conv, 3.15, GTO sk, hdr, meth, pint/tb, tune, & more DR - (6617)
10.150 @ 138.16 - RV00GT - 08 M6 NPP - CAI, cam, hdr gto skinny, N2O, tune, DR - (6498)
10.248 @ 139.15 - Slowsome - 08 M6 F55 - ECS Novi, cb, fuel system, H&C, hdr, meth, tune, DR - (5556)
10.276 @ 135.55 - Detoxx03 - 08 M6 - SC, alky, cam, pfadt, tune, DR - (6545)
10.482 @ 137.50 - Cusvt - 08 A6 NPP - Cam, hdr N2O, tune, DR - (6813)
10.551 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdr, tune, DR - (3232)
10.575 @ 135.18 - Winters 97 GT - 08 M6 - SC, alky, B&B mufflers, tune, DR - (5029)
10.704 @ 136.61 - ZbadestZ - 08 A6 NPP - ECS 2200, hdr, fuel system, tune DR - (5021)
10.732 @ 133.32 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune, DR - (6262)
10.872 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdr, SC, tune, DR - (3899)
10.879 @ 129.37 - ShawnBrumley - 08 A6 - Eforce SC, tune, DR - (6627)
Power Adders Grand Sport (supercharger, turbo, nitrous)
10.264 @ 138.91 - DCI - 11 M6 GS - SC, cam, hdr,smaller pulley, tune, DR - (6803)
10.657 @ 134.70 - Fordracer9 - 10 A6 GS - SC, hdr, meth, xpipe, tune, DR - (5654)
11.329 @ 124.01 - CaptainBob - 11 A6 GS - Eforce SC, hdr, DR - (6507)
11.399 @ 123.44 - Thomasmoto - 11 A6 NPP - Eforce SC, hdr, M2W switch, DR - (6503)
Larger Displacement (All entries)
07.982 @ 174.44 - Tluck - 05 A4 Z51 - 427cid, turbo, power glide, eldbrock intake, coil overs, & more, tune, DR - (6296)
09.513 @ 148.77 - Todd@RPM - 05 A4 -TT, 427cid, fuel sys, 3.42, L92 heads, RPM Trans, tune, DR - (4274)
09.680 @ 139.20 - JThurik - 10 A6 GS - 377 forged internals, SC, hdr, meth, xpipe, tune, DR - (6722)
09.681 @ 148.36 - Winters 97 GT - 08 M6 - 402, SC, alky, B&B mufflers, tune, DR - (5881)
09.751 @ 147.05 - Icevettez06 - 05 M6 - 402 APSTT, alky, fast, fuel system, Z06 trans, more, tune, DR - (6301)
09.890 @ 138.61 - Pete Champion Motors - 06 A6 – 502 cid, cam, conv, cust intake, hdr,3.15, ph, tune, DR - (6642)
09.895 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, tune, DR - (4273)
09.950 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, tune, DR - (4465)
10.231 @ 136.86 - Deecount - 09 A6 Npp 2.73 - SC LPE 427, cam & pheads Ls9 Intake, more tune, DR - (6727)
10.416 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, 3.42, hdr, tune, DR - (4194)
10.470 @ 130.89 - Craftfox - 07 A6 Z51 – 440cid, conv, fast, 3.42, hdr, tune, DR - (4444)
10.529 @ 138.03 - Icevettez06 - 05 M6 - 402cid, apsTT, alky, fast, hdr, qual, tune, DR - (5297)
10.689 @ 133.21 - Schilitj - 05 M6 Z51 - 402cid, SC, cb, H&C, hdr , tune, DR - (3525)
10.761 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (778)
11.439 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416cid, conv, pfast, H &C, ptb, tune, Nitto Ivos - (3736)
11.689 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (658)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.114 @ 118.10 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 3.90, tune, DR - (6523)
6.519 @ 107.03 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdr, tune, & more DR - (4688)
6.894 @ 104.37 - Rmac6 - 11 M6 GS - CAI, cb, drag pack, ported heads hdr, tune, DR - (6876)
6.945 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, fast, H&C, ptb, 100maf, tune, DR - (4357)
7.19x @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdr, DR - (3782)
7.145 @ 97.67 - Carlrx7 - 06 A6 - CAI, cam, conv hdr, tune, DR - (6393)
7.213 @ 95.10 - Joe G - 05 M6 Z51 - CAI, cam, 3.90, pfast, hdr, tune, DR - (3788)
7.279 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.275 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdr, pi/tb, C5-3.90, tune DR - (4530)
7.342 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, tune, DR - (3052)
7.353 @ 94.30 - Tiresmoke69 - 13 A6 - Conv, tune, Dr - (6808-6809)
7.36x @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdr, 3.90, Et Street - (2863)
7.50x @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi/tb, hdr, tune PS2s - (3081)
7.65x @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdr, tune Dr - (3558)
7.676 @ 94.37 - DavetteGuy - 08 A6 - CAI, Ptb tune - (5064)
7.835 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdr, pi, nitto ivos - (4160)
7.866 @ 92.80 - Brywood - 08 A6 - Cai, cb, hdr, tune (6801)
8.096 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4042)
8.215 @ 102.13 - ATLS2 - 06 A4 - SC, meth, cam. cb, hdr, tune, DR - (6837)
8.428 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1660)
#6877
CATEGORY: POWER ADDERS LS3
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # _____
3. The complete the details of your pass using this template in your post:
4. Year Corvette: '08 Base
5. Type of Trans: A6
6. Type of Suspension: Stock
7. Stock Performance options (as in optional gears with the automatic, & etc.): Base LT3
8. Tires utilized: 275/40R17 DRs
9. Modifications if any: A&A V3 trim SC, AR Longtubes, Cam, Meth, Tune
10. Dyno numbers if you have them:
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc: Stock Converter, trans, and gears. Launching from Idle (850 rpms)
___ Name of the Track: Evadale Raceway
___ Date of the pass & weather conditions 10/18/14, ~80* w/ 90% humidity, DA 1000'
___ 60'.............1.708
___ 330'...........4.448
___ 660'...........6.720
___ 660’ mph....107.53 mph
___ 1000'.........8.659
___ 1320'.........10.30
___ 1320’ mph…136.99 mph
Still dialing in and as the weather/ humidity comes down here in Louisisna I'm hoping to see some quicker times. My tunerCody, (TUCN26 on the forums) has the power-adder LS2 record so i'm in good hands.
#6878
First time at the track!
Finally took my 10' M6 Grand Sport to the track. If the day goes well I will have a 1/4 time slip to share after tonight (The Texas Motorplex is open for a rare Test n Tune tonight).
1st pass dropped the clutch at 2k and eased into throttle...bogged bad.
2nd pass 3500 launch...too much, spun hard.
3rd pass was a charm and I took her home after that (very happy with the MPH):
Category : Internal Engine Mods/Grand Sport
4. 2010 Grand Sport
5. M6
6. Stock
7. Stock
8. 345/30/19 Nitto NT05R's
9. Headers, hi flow cats, CAI, Cam, ported throttle body, 160 stat, QMS Tune, stock unopened long block
10. 472rwhp 115 degree shop ambient that day
11. 20psi rear tires, no burnout, hit it to clean the tires off, dumped the clutch at about 2500 RPM and hammered it, spun pretty hard but the 60' is decent (I think?)
___ Northstar Dragway (Sanger, TX)
___ 10/23/14 8:45pm, 74 degrees?
___ 60' 1.7582
___ 330' 4.8707
___ 1/8th mile ET 7.4608
___ 1/8th mile MPH 98.45MPH
4. 2010 Grand Sport
5. M6
6. Stock
7. Stock
___ 60' 1.7582
___ 330' 4.8707
#6879
showroom stock ls7 427
A couple notches better for a RESET on my time
2013 427 white commemorative addition
M6
same issue with the clutch now broken in at 2k miles... thought something with the master cylinder opened up the resevoir and iTS DIRTY DIRTY DIRTY.. still got okay runs out of it!!!
it still would drop to the floor on 4000rpm launch.. AGAIN got decent launch off 3500rpm(BOGS bad at 3,200 rpms) with VERY VERY gentle release off the clutch... trapped on 3rd gear everytime.. on this particular run MPH was high enough to hit rev limiter at the end... OH and Because of master cylinder issue missed 2nd on this Run as follows as I can Tell from My 11.72 run that I dropped 2mph at 1/8mph mark...
___ cecil County 10/25/2014
___ 50s then high 60s at this run
___ 60'.............1.863
___ 330'...........5.046
___ 660'...........7.621
___ 660’ mph....93.39
___ 1000'.........9.816
___ 1320'.........11.647
___ 1320’ mph…123.13
M6
#6880
Category:LS3 internal
5. Type of Trans A6
6. Type of Suspension Base
7. Stock Performance options (as in optional gears with the automatic, & etc.) 2.56 Gears
8. Tires utilized et street bias 26x11.5x16
9. Modifications: honker intake, 1.75" longtunes with bullet mufflers and turn downs 3200 fti stall, ky speed spec cam, bluecat tune
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc 16psi rears 40 psi fronts 1/4 tank of gasoline, lflashing the converter
___ Name of the mountain park dragway in kentucky
___ Date of the pass & weather conditions 10/26/14 1980 da
___ 60'.............1.643
___ 330'...........4.631
___ 660'...........7.087
___ 660’ mph....99.529
___ 1000'..........
___ 1320'......10.954
___ 1320’ mph….129.585
