C6 1/4 Mile Performance Challenge
#6921
Got a new PB yesterday, ready to hit the track again soon to get it a little better. Trying to get the fastest M6 bolt-on time before heads/cam this winter.
Category : LS2 External Modification
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # _6924_
3. The complete details of your pass using this template in your post:
4. Year Corvette : 2007
5. Type of Trans : M6
6. Type of Suspension : Z51
7. Stock Performance options (as in optional gears with the automatic, & etc.) : Z51
8. Tires utilized : 275/40/17 Hoosier DR's on chrome C5 ZO6 replica's/ GTO spares with M&H Racemaster Bias-Ply
9. Modifications if any : AR Headers w/Cats, Corsa Extreme CB, Callaway CAI, MGW shifter, Ported FAST 102, Ported stock TB, RPM stage 4 rear w/4.10 gears, ATI 10% UDP, Mantic 9000 Clutch, 160 t-stat, Deka Battery, Vette Doctors Tune
10. Dyno numbers if you have them : 412hp/419tq
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc : 20psi rear tires/ 40psi fronts, passenger seat and front sway bar removed, 1/8th tank of gas, 240lb driver, car without driver was 3025
___ Name of the Track - Atco
___ Date of the pass & weather conditions -11/10/14 50 degrees
___ 60'.............1.589
___ 330'...........4.789
___ 660'...........7.384
___ 660’ mph....93.75
___ 1000'.........9.583
___ 1320'.........11.420
___ 1320’ mph….124.60
Copy of Time Slip Below:
I don't know how but my tail light popped out when I launched the car. Pretty funny though. Here is the only vid that has been posted so far, I know there are more coming....lol
#6924
Category:Internal grandsport modifications
Rz_ls3vette
Year 2011 grandsport
Type of Trans A6
Type of Suspension stock
Stock 2.56 gears
Tires utilized Hoosier 315/35/17
Modifications: cam, CAI, Conv, Fast, Z06 Exhaust, Longtubes,tune
No weight reduction full weight no skinnies
___ Name of the Track Famoso speedway Bakersfield ,ca
___ Date of the pass 11/09/14 warm
___ 60'.............1.535
___ 330'...........4.557
___ 660'...........7.074
___ 660’ mph....97.84
___ 1000'.......... 9.244
___ 1320'..........11.086
___ 1320’ mph….122.46
Rz_ls3vette
Type of Trans A6
Stock 2.56 gears
#6926
Category:Internal grandsport modifications Rz_ls3vette Year 2011 grandsport Type of Trans A6 Type of Suspension stock Stock 2.56 gears Tires utilized Hoosier 315/35/17 Modifications: cam, CAI, Conv, Fast, Z06 Exhaust, Longtubes,tune No weight reduction full weight no skinnies ___ Name of the Track Famoso speedway Bakersfield ,ca ___ Date of the pass 11/09/14 warm ___ 60'.............1.535 ___ 330'...........4.557 ___ 660'...........7.074 ___ 660’ mph....97.84 ___ 1000'.......... 9.244 ___ 1320'..........11.086 ___ 1320’ mph….122.46
#6928
category ls3 power adder
4. Year Corvette 2008
5. Type of Trans A6
6. Type of Suspension Base
7. Stock Performance options (as in optional gears with the automatic, & etc.) 2.56 Gears
8. Tires utilized et street bias 26x11.5x16
9. Modifications: honker intake, 1.75" longtunes with bullet mufflers and turn downs 3200 fti stall, ky speed spec cam, bluecat tune, 90mm plate kit 150 shot
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc 16psi rears 40 psi fronts 1/4 tank of gasoline, lflashing the converter
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track. London Dragway kentucky
___ Date of the pass & weather conditions 11/9/14 1000da
___ 60'.............1.5412
___ 330'...........4.2662
___ 660'...........6.5006
___ 660’ mph....110.35
___ 1000'..........
___ 1320'......10.0306
___ 1320’ mph….138.50
5. Type of Trans A6
___ 1000'..........
#6931
ls7 427 Bone-Stock except Non-Stock Tires
Category:LS7 427 bone stock except non stock tires
Had the Same Master cylinder issue.. Need to Bleed it Better.. finally learned to baby it at 3,000 rpm and got a 2.0 to a 11.9... then tried few times 3500 rpm and finally got a decent launch... FULL TANK in CAR.... After this pass I GOT a 1.71 short Time BUT missed 2nd -- cylinder issue again ??--- with the smaller tires I had to shift into 4th right at the end everytime...
4. Year Corvette 2013
5. Type of Trans m6
6. Type of Suspension z06
7. Stock Performance options z06 powertrain
8. Tires utilized hoosier 315-35-17
9. Modifications: NONE
___mir corvetteforum Rental
___ 11/14 COLD cold not sure of DA
___ 60'.............1.769
___ 330'...........4.853
___ 660'...........7.395
___ 660’ mph....96.69
___ 1000'.......... 9.558
___ 1320'..........11.385
___ 1320’ mph….122.38
5. Type of Trans m6
#6932
5. Type of Trans m6
___ 660 mph....96.69
___ 1320 mph .122.38
5. Type of Trans m6
#6933
BUT thoughts? My c5 z06 Never EVER had THIS issue with 250+ passes.. WHY is this happening TO what is suppose to Be c6z06 drivetrain (clutch) ??!!
#6934
suck out all he old clutch fluid and put fresh in before making passes. if u never done this. do it a couple times after a few passes. makes a big diff. always helped mine.
#6935
Category : External Mods - Bolt Ons
2. A copy of your entire time slip posted to the thread as in post # _____
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2011 GS
5. Type of Trans A6
6. Type of Suspension Stock OEM
7. Stock Performance options (as in optional gears with the automatic, & etc.) NA
8. Tires utilized MT 265/40-18 DR
9. Modifications if any Airaid CAI 250-230
10. Dyno numbers if you have them none
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc Preload OEM stock conv to 1600 +/- , 31 lbs in front OEM run flats, 18 lbs in DR
___ Name of the Track Atco Dragway, NJ
___ Date of the pass & weather conditions 11/20/14 - warm for time of year
___ 60'............. 1.875
___ 330'........... 5.123
___ 660'........... 7.743
___ 660’ mph.... 93.64
___ 1000'......... 9.993
___ 1320'......... 11.884
___ 1320’ mph… 121.44
5. Type of Trans A6
#6936
5. Type of Trans A6
5. Type of Trans A6
#6937
How do I get on this list I have a time slip and video
06c6 stock clutch stock suspension 450whp 400tq kook headers xpipe corsa back vararam ported tb cam and tune 6 speed trans
#6938
Category : Stock LS3 Grand Sport
2. A copy of your entire time slip posted to the thread as in post: 6939
3. The complete details of your pass using this template in your post: Yes
4. Year Corvette : 2013
5. Type of Trans : MN6
6. Type of Suspension : F55, Magnetic Ride set to Sport
7. Stock Performance options (as in optional gears with the automatic, & etc.) : None
8. Tires utilized : P275/35R-18:Front & P325/30R-19:Rear | Bridgestone Potenza RE050A Pole Position RFT
9. Modifications if any : None Stock Powertrain
10. Dyno numbers if you have them : Never dynoed although the Butt says around 400RWHP@390lb/trq
Ran it in daily driven trim:
- after-market 10" sub with all wires, harnesses, and amp.
- Exhaust commander controller bypassed for always open NPP operation.
- Driver 205lb driver, car weight unknown.
- ~31psi front/rear tires, less than 1/8 tank of gas.
- tires @ 25k miles with less than 4mm of tread left on rear
- TC/AH set to Competitive Driving Mode
- Mild to sometimes sloppy 1st gear burnout in the box
- Attempted to launch between 3100-3300 RPMs, little to no traction from 3500RPM and above
___ Name of the Track - Fayetteville Motorsports Park
___ Date of the pass & weather conditions -11/9/14 ~60 degrees, DA: 525' via Dragtimes Webstite
___ 60'.......... 1.8857
___ 330'........ 5.3249
___ 660'........ 8.1299
___ 660’ mph.... 89.29
___ 1000'........ N/A
___ 1320'........ 12.506
___ 1320’ mph....112.56
#6939
Bridgestone RFT= Handicap over stock RFT weight.
Those Bridgestone run flats actually weigh more than the Goodyear run flats so you were at a slight handicap on the tires over stock. I liked the way you filled out your form. I have noticed lately that a few have left out the fact that they also had a tune, etc.
