C6 1/4 Mile Performance Challenge
#7121
Personal best with a lot left in it.
Category: C6 Power Adders LS3
4. Year Corvette: 2008
5. Type of Trans : A6 Century built
6. Type of Suspension: All stock
7. Stock Performance options: NPP
8. Tires utilized: Hooser 315/35-17, M&H 185/55-17 on Welds
9. Modifications if any: RPM 342 rear, ECS Novi 1500, Alky Control meth injection, Kooks Headers & X pipe,
10. Dyno numbers if you have them: 680 RWHP
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc : This was not a clean run but I hooked good. I hit rev limiter in 1st and 2nd and broke loose and got sideways at the big end and coasted across the line at 123.94
12 Typed in the post (as some time slips get deleted & etc. after being posted)
Name of the Track: Capitol Raceway Crofton MD
___ Date of the pass & weather conditions: 10-16-2015, sunny and 55 degrees with a -266 DA.
___ 60'.............1.562
___ 330'...........4.484
___ 660'...........6.781
___ 660’ mph....106.49
___ 1000'.......... 8.730
___ 1320'..........10.473
___ 1320’ mph….123.94
#7122
It had to be the cam because the first motor never saw nitrous. It broke out of no where doing a burnout on my first pass of that day. And to make all matters better it was on mustang night lol. So I was getting a earful from the ford guys. I honestly thought an injector failed or a valve hit the piston but i still have the original injectors in it working perfect and the valves/valvetrain looked good. Minus the 2 valves in the cylinder being ever so slightly bent from all the little chunks of piston that got scattered through the whole motor. That first motor was always kind of a pig until I put some mods on it. Hence the 3rd slowest bone stock time.
#7123
#7124
The C6 LS3 has been out for over 8+ years now and I still can't believe it's taken this long for a bolt ons only example to get into the 10.7s.
Congrats on some very stellar passes, David.
#7127
Received 2,060 Likes
#7129
Lol wow that happened to you too? Well I guess that makes it the winning combo. Calling all bolt on ls3 owners, time to blow your motors, get a new longblock and run 10s.
#7131
Category: 2013 427 tire ONLY (bolt-ons)
4. Year Corvette: 2013
5. Type of Trans : stock
7. Stock Performance options: NPP standard
8. Tires utilized: Hoosier 315/35-17 on c5z rims
9. Modifications if any: NONE
11. Nursing the famous "clutch" which I believe is the master cylinder., tires work too good for it as well,. launched at around 3600rpm slipping clutch (carefully -- if slip too much it will SLIP all the way)-- then on gas WOT sooner then usual to get car launched prob around 10' mark... shifting to 2nd is sloppy., getting better 2 to 3 but loosing time on 1-2 and 3-4--- this car can run the 1/4 in 3rd with stock tires so will try that again soon
Name of the Track: Cecil county MD
___ Date of the pass & weather conditions: 10-28-2015, cloudy and 60 degrees
___ 60'.............1.782
___ 330'...........4.850
___ 660'...........7.385
___ 660’ mph....98.65
___ 1000'.......... 9.484
___ 1320'..........11.288
___ 1320’ mph….123.34
#7132
New PB 10.09 at 132.94
Tommy could you please update my new time.
Category : LS3 Internal Modifications
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post #_____:Time slip posted below
3. The complete the details of your pass using this template in your post:
5. Type of Trans: A4
6. Type of Suspension: Z51 with LG coilovers JOC rear sway bar front sway bar removed
7. Stock Performance options stock NPP exhaust, Deleted Mufflers
8. Tires utilized: Hoosier 275/40/17 on C5 fronts and GTO Spares with M&H tires
9. Modifications if any: G6X3 cam and ported stock heads, UDP, EWP, A4 with 3.42 Diff, Yank 4000 ss conv, 1 7/8" LTH with cats, Vararam cold air with filter, drag radials, Ported stock intake, NW 102 TB, Meth Injection, James Karger Tune.
10. Dyno numbers if you have them 522.3 RWHP, 494.9 ftlb torque.
11. As much info you may want to add about the run, launch techniques, tire air pressure 18 PSI, 6800 shift points, Tires spun on launch
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track: Royal Purple Raceway
___ Date of the pass & weather conditions: Sunny Clear 12/4/2015. 48 degrees. DA -800 to -900 using meter at track
___ 60'............. 1.369
___ 330'........... 4.083
___ 660'........... 6.398
___ 660’ mph.... 106.34
___ 1000'......... 8.400
___ 1320'......... 10.094
___ 1320’ mph...132.92
Time Slips Royal Purple 12-4-15
#7133
Side note: I still don't get why some tracks are so cheap and cut the timeslip in half.
#7134
^^^ Great times! Wow so close to single digits.
FYI they cut the slips normally when they are running no times. No boards and you can't see your opponent's times.
#7136
According to RPR website, the 4th was a legal street racing event and not a timed competition. Kinda like a free-for-all or TnT where there are no opponents. Even if you had opponents, why would it matter after the race was over? None of the 22 tracks where I've run issue half slips. Then again, back in the 50's/60's you'd get a Post-it size slip with only your car number, ET, and MPH hand written. Maybe I just need to expand my horizons.
#7137
#7139
They turned the boards off during the arm drop portion at Pinks All Out, but that was after all the guys with electronics got their 10 second car dialed in and the TV cameras were turned on. Viewers never saw the qualifying. Kinda funny watching 4 or 5 cars in a row posting up a 10.000 to qualify and then one guy a 10.001. I was in the 11.0 group and never stood a chance.
#7140
