C6 1/4 Mile Performance Challenge
#7284
4. Year Corvette. 2008 base
5. Type of Trans. A6
6. Type of Suspension. Stock base with z51 struts
7. Stock Performance options (as in optional gears with the automatic, & etc.) Factory 2:56 gears
8. Tires utilized. Stock run flats up front m&h drag radials on 17" zo6 replica wheels 18psi cold
9. Modifications if any. Tfs 255 heads, yank 3200, kooks LTs with no cats, NPP muffler, cmc-20 cam, BER ported ls3 manifold, ported stock throttle body
10. Dyno numbers if you have them. Unknown
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc.
foot brake to 2000rpm rear tires 18 psi cold front 30psi cold on the run flats
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track Ben bruce memorial air park raceway
___ Date of the pass & weather conditions 28 Jan 2017 -300 da
___ 60'............. 1.66
___ 330'........... 4.66
___ 660'........... 7.14
___ 660’ mph.... 99.21
___ 1000'......... 9.27
___ 1320'......... 11.05
___ 1320’ mph… 126.44
this was the best na run. Didn't get a clean nitrous pass
#7286
Looks like Tommy hasn't been on in quite a while, does anyone else know how to reach him?
Tommy D Tommy D is offline
CF Senior Member
Last Activity: 09-30-2016 07:56 PM
CF Senior Member
#7287
#7288
New personal best 2008 C6A6 with Z51, factory take off Z06 NPP exhaust,E85 tune,drag radial NT-05 Nitto 275x40-17, Lingenfelter torque converter for C6A6 with 45%higher stall which approximates the OEM converter in the C7. 11.79 see time slips.
#7289
___ 330'........... 4.62
___ 660'........... 7.09
___ 660’ mph.... 99.80
___ 1000'......... 9.21
___ 1320'......... 10.98
___ 1320’ mph… 127.08
#7290
4. Year Corvette. 2010GS
6. Type of Suspension. Stock GS
8. Tires utilized. Stock run flats all around 26 psi.
9. Modifications if any. none
Air was good, about 55 degrees at Texas Motorplex in Ennis TX. Run flat tire pressure set to 26 psi. traction control off, went around the water, backed in to the box and did about a 2 sec burnout, launched at 1100 rpm.
___ Name of the Track Texas Motorplex Ennis, TX
___ Date of the pass & weather conditions. Feb 25, 2017. 55 degree
___ 60'............. 1.969
___ 330'........... 5.408
___ 660'........... 8.179
___ 660’ mph.... 88.91
___ 1000'......... 10.547
___ 1320'......... 12.519
___ 1320’ mph… 114.70
I'll chip in. Completely stock, no tune, CAI cat back or other mods.
Very pleased, bragging rights to a mid-12 second street car, heck yes!
MidYearRoadster (03-22-2017)
#7291
I'll chip in. Completely stock, no tune, CAI cat back or other mods. Air was good, about 55 degrees at Texas Motorplex in Ennis TX. Run flat tire pressure set to 26 psi. traction control off, went around the water, backed in to the box and did about a 2 sec burnout, launched at 1100 rpm.
#7292
I only had a bit of tire spin. I'm sure the track surface prep makes a huge difference!
#7293
I didn't change anything tire pressure was 30 small burn out. The track i was at every car I've used street tires there is slick like ice. 60ft was horrible like a 2.1 but that was when I first got the car and it ran high 11s on drag radials. Plus my run flats are getting old and bald.
#7294
Even if you get a decent pass on run flats, there is no way to be consistent. Drag radials are next on my upgrade list.
#7295
4. Year Corvette. 2013 Grand Sport
7. Stock Performance options (as in optional gears with the automatic, & etc.) z51
8. Tires utilized. Hoosier Drag Radials 315/35/17 zr1 wheels
9. Modifications if any. Cam, converter, headers, exhaust and tune
10. Dyno numbers if you have them. Street Tune
___ Name of the Track. Royal Purple Raceway
___ Date of the pass & weather conditions. Sunny about 70*
___ 60'............. 1.577
___ 330'........... 4.554
___ 660'........... 7.045
___ 660’ mph.... 101.78
___ 1000'......... 9.204
___ 1320'......... 11.044
___ 1320’ mph… 122.77
#7297
#7299
Thanks! I'm lacking trap speed! When I turn on the bottle it should pick up. I want a 10 on motor 1st.
https://www.youtube.com/watch?v=i_Y7AjGyypA
