how much will a 4.10 rear improve 0-60 time
3rd Gear
I have a 2007 c6 and I am thinking about a new 4.10 rear. How much will it improve my 0-60 or 1/4 mile time?
On a drag radial/ET Street 'slick' tire you will see a vast improvement once the tires are heated properly (and if the clutch holds).
Spin Dr.
I have 4:10`s in my 06` convt, with some mods, and I can tell you, with the traction control off its a tire spinning contest from a stop in 1st. So should I start my 0-60 time, after I hook up??? LOL!!!
There are way to many variables to factor in to just give you a number.
Tire grip, engine power, engine redline weight all play a part.
You will also need to factor in shifting since it will take place earlier.
Do you have a manual or an auto?
If you have an auto then a torque converter with stock gearing would be a better bet than just switching to 4.10s.
In a manual 4.10s would be a beast though.
Note that you WILL need tires to fully use them.
