RaceLogic Traction Control?
Old 02-16-2008, 12:51 AM
ProgGod
ProgGod's Avatar
Originally Posted by Rainmaker
I'm doing the anti-rain dance for the next week in AZ so we can get a report on your new system!
Can Rain Makers prevent the rain?
Old 02-16-2008, 12:31 PM
Rainmaker
Rainmaker's Avatar
Only if the Rain Gods cooperate.
Old 02-16-2008, 04:18 PM
ProgGod
ProgGod's Avatar
Need to hook up power and a tach signal still. Going to do that tommorow.
Old 02-22-2008, 10:54 PM
ProgGod
ProgGod's Avatar
Just an update.... been spending last few days narrowing down a problem. When we have it turned off, but plugged into the loop we got alot of smoke. Seems like its throwing in alot of extra fuel. Removing it from the loop we don't have any issues. Tried swapping out the controller but we have the same problem. Must be a wiring issue. Going to try and narrow it down monday.
Old 02-23-2008, 12:21 AM
Rainmaker
Rainmaker's Avatar
Thanks for the update.
Please keep us posted.
Old 02-23-2008, 01:17 AM
ProgGod
ProgGod's Avatar
Found the problem, the shop that started the install had wired into the wrong wires in the harness. Going to wire them directly into the injector wires in the morning. Should have it working tommorow!
Old 02-23-2008, 03:17 PM
pennys58
SC CF Senior Member
Support Corvetteforum!
pennys58's Avatar
St. Jude Donor '06-'07-'08
John
Old 02-23-2008, 04:08 PM
ProgGod
ProgGod's Avatar
Originally Posted by pennys58
John
Just got done with 5 out of 8 cylinders Taking a break.
Old 02-23-2008, 07:12 PM
ProgGod
ProgGod's Avatar
Alright guys its in and working great. Now I just need to spend some time tuning it and getting it dialed in. Ended up ripping out everything the previous shop did and rewiring it all totally. Took me about 3hours total. Pretty easy system to install I have to say. Stay tuned for tests tommorow :0
Old 02-26-2008, 11:39 AM
pennys58
SC CF Senior Member
pennys58's Avatar
I am on the edge waiting to hear about this
John
Old 02-26-2008, 11:59 AM
ProgGod
ProgGod's Avatar
John
Having other issues.. Right now transmission is slipping. Taking it back to XMS to check that out tommorow. T/C is installed, now I just need to test.
Old 03-03-2008, 04:05 PM
pennys58
SC CF Senior Member
pennys58's Avatar
John
Old 03-03-2008, 05:53 PM
  #33
ProgGod
ProgGod's Avatar
Car is sitting up on my rack with entire rear end out of it. Drive shaft was bent, hopefully new carbon fiber one should arrive tommorow.
Old 03-04-2008, 06:38 PM
  #34
jhester
jhester's Avatar
I also have past experience with both a Bosch system and the RaceLogic system.
For 99% of the individuals who would be interested in a TC system, RaceLogic will do a fine job.
The Bosch system is a true PID controller, which will allow you to match the TC curves to the slip curves of the specific tire and track surface. Then you can modify those curves over 12-possible switch positions. If you do not have a firm understanding of PID feedback systems and how they can be used with tire slip tables, you need not apply for the Bosch.
The Bosch is used by top sports car teams; all GrandAm teams, Audi LMP1, Corvette GT1, LG Motorsports Corvette GT2, etc to name a few.
Great system, but it EXTREME overkill for the average consumer.
Its the classic 80/20 rule, The RaceLogic system is 80% of the function, 20% (or less) of the cost of the Bosch.
Old 03-04-2008, 10:43 PM
  #35
ProgGod
ProgGod's Avatar
I just wish my driveshaft would arrive so I can give the thing a good test. Would really like to have the car tuned and ready for the races this weekend.
Old 03-11-2008, 02:47 AM
  #36
pennys58
SC CF Senior Member
pennys58's Avatar
Did you ever get the drive shaft in so you could test/tune the Racelogic TC? Keep us updated!!
John
Old 03-11-2008, 03:05 AM
  #37
ProgGod
ProgGod's Avatar
Still waiting on the driveshaft Apparently shipment is delayed. Also noticed my bell housing was cracked. That should arrive wednesday. If all goes well should be testing thursday.
To RaceLogic Traction Control?
Old 03-11-2008, 01:46 PM
  #38
Danny318
Danny318's Avatar
nice
Old 03-11-2008, 03:45 PM
  #39
AU N EGL
AU N EGL's Avatar
Originally Posted by Louis @ LG Motorsports
Expect to spend 30-40K for a properly calibrated Bosch MS 4.3 and wiring harness.
I think 12.5% will be just fine
WOW dont think I will look at the Bosch then
Hmmmm Launch Control . . . .
Old 03-17-2008, 08:08 PM
  #40
pennys58
SC CF Senior Member
pennys58's Avatar
What's the word??
John
Quick Reply: RaceLogic Traction Control?
