Jacking with a cross beam adapter
I'm considering purchasing a cross beam adapter to jack the C6. I especially like the prospect of being able to jack the car up with the cross beam adapter on the jack saddle, then place jack stands under the cross beam adapter, and remove the floor jack. However, my floor jack does not have a hole in the saddle to bolt the cross beam adapter to. Are cross beam adapters safe to use without being secured to the jack saddle?
Cheers,
Ian.
Cheers,
Ian.
Cheers,
Ian.
Cheers,
Ian.
Your results may vary...but I say save your money.
The key is a low jack. I use the cheap $79 racing jack from Harbor Freight, 6 years old and tons of use and still going strong.
I have a crew of about a dozen guys who race with me who do exactly the same thing since 2005 (corvette challenge) by the way.
I've been jacking my C5 and now my C6 in the middle of the front or rear crossbeams with no adaptors nearly weekly for 6 years now with no problems. I put the stands on the ends of the crossmember but leave the jack in place with very slight tension just as a backup in case the stands slip (which has happened on my slightly sloped driveway).
According to every source I've seen, jacking from the middle of the cross beams is a no-no. I can get a cross-beam adapter for about $60 shipped, but now you've got me thinking... is it really safe to jack in the middle of the cross beams?
Cheers,
Ian.
That's exactly the jack I've got! Except, I paid $190 for mine (I'm in the UK).
Cheers,
Ian.
Cheers,
Ian.
I've also read those jacks are junk...you read all sorts of things here.
I've been doing both for 6 years almost weekly as I race a lot. I can't say if your results will be the same as me and all my buddies...at $60 it's not a lot of money if it makes you feel better!
We lug our tires and that jack in the backs of our cars to the track, so to us less is more, no room for a cross adaptor and I'd be afraid you'd have to drive the car on ramps before it would all fit! What a pain that would be...
Cheers,
Ian.
I have a cross beam adapter, except I call it a 2x4. You can jack them up on the cross beams no problem. But if you are worried, a 2x4 works nicely.
