2008 LS3 Mobil 1 Oil Filter #
Can anyone tell me what the LS3 oil filter number is? I thought it was different from the LS2 but Advance is showing the same part number for both.
Thanks,
Dan
Thanks,
Dan
The 2007 and the 2008 owners' manuals show the same filter, PF48, part no. 89017524. It did specify the 2007 was for the 6.0 L engine, and the 2008 was for the 6.2 L engine.
PHOTOSHOP SPECIALIST
Mobil 1 Oil Filter - - M1-113
Fits:
2007 6.0 Liter
2008 6.2 Liter
oil filter 101
I like the wix too, I went back to the stock pf-46 on my 06 because, If you look at the top of any oil filter you've got the single big hole and the six smaller hole's compare the size of the holes the mobil filter holes are about half the size of the stock and there's some kind of o-ring right under the holes futher blocking flow, remember you want volume not pressure, choose the filter with the bigger holes
Starting in 07, the bypass was moved from the engine to the filter, so the 07 and 08 use new PF48 or 113 or 10060. In 05 and 06 it was PF46 (improved Pf44) and 107...
