Adding Steering Wheel Controls
#41
There is a grey connector at the back of the radio with 2 missing wires and terminals at locations A6 and A7. That is where the circuits for the radio control go. The terminals needed are 12146447. And those wires will need to be run all the way to the steering column coil.
#42
Looks like I have a new winter downtime project.
#43
Radio controls
I just installed a 2007 wheel with the radio switches in my 2005. Do you know if the 2005 radio will be compatable with these controls? On another note, I think I may have a bad clockspring as I now have an airbag light and the horn doesn't work. Any thoughts on this? Thanks.
#46
I used a 5k potentiometer connected to the radio to simulate the controls but it had no effect. This was on a 06 3lt radio. At this point I'm assuming at least an 07 radio is needed for this to work.
#47
1 Post
Hey guys, just wondering what ever happened to this issue? Who was able to complete it and get everything to work properly?
I have an 06 with BOSE and navi, so I'm assuming I have the correct deck (will just have to get it reprogrammed as mentioned earlier in this thread).
I guess what I'm confused on is what are all the parts I need to get, and what is a clock spring? How will the steering wheel from an 07 communicated with my 06 non radio control column? What transfers the current? I'm assuming it's not just wires running from the steering wheel to the radio as the wires would get pulled or tangled when turning the wheel?
I can get the 07 steering wheel new for around $230 bucks, but can you guys please tell me what other parts I'll need? I would love to order everything and get this project going.
#52
I ordered and installed:
*2007 steering wheel w/radio controls
*2007 clockspring (for cars with radio controls)
The 2007 Clockspring has two ends. One set of end connectors connects under the steering wheel airbag, and the other clockspring end has a pair of connectors that connects to wiring on the bottom end of the steering column under the dash. There are two sets of plugs on each end of the clockspring... a set for the airbag and another plug for the SWC/Horn/ShiftPaddles (if your car is an automatic)
The airbag wiring to the new clockspring is straight-forward plug and play on both the steering wheel end and the column end. No mods needed.
The SWC/horn/paddleshift plug however is a different story. On the steering wheel end, the new plug just plugs in to the matching plug on the 2007 wheel -- couldn't be easier. BUT, on the under-steering-column end, its not so easy. The wires for the horn/paddleshift exist in the 2006 wiring, and while not plug and play (plugs are different) its easy enough to tap/splice the horn and paddleshift wires to the existing wiring. The problem is the 3 wires for the SWC: the SWC source wire, the SWC signal wire, and SWC illumination wires simply do not exist in the 2006 wiring loom, and must be fabricated.
I spliced the SWC illumination wire to the illumination wire connected to the HUD control switch on the LH dash pod. I extended the two SWC wires (source wire and signal wire) and ran them to the back of the radio. This is where we hit another issue: the two needed cavities for SWC's in the radio plug (A5 and A6, if I remember correctly), are EMPTY on 2006 cars, so we cant just splice into an existing wire. So now we have to find the correct terminals, solder them to the SWC extension wires and pop them into the radio connector.
Ok, finally got all that done, and the SWC buttons illuminate properly, but do NOT work to change stations, change tracks, nor control volume. Nothing works. Damn.
My theory is that, along with a 2007 steering wheel and a 2007 clockspring, you also need a 2007 or later BOSE (or uplevel enabled) radio to utilize the signal from the SWC.
#53
I don’t know about knowledgeable, but I did find some answers today. I decided to use my car as a guinea pig, and it was slow at work today. I can say that this IS POSSIBLE but it’s more work than I thought it would be. Of course you will need a new coil assembly at the top of the steering column and switch. But the radio switch bezel is not available separate from the steering wheel. And the wiring harness from the switch to the steering column coil can only be acquired with the steering wheel too. The vehicle harness from the radio to the steering column does NOT contain the 2 circuits needed for the switch. Some terminals would be needed and 2 wires run to the radio along with running a lamp dimming circuit to the column.
The radio will not make use of the new switch inputs until it’s reconfigured. The base U66 option with a Delco amplifier will not work. The premium U65 using a Bose amp will work. Using a Tech2 I had to change the option configuration in the radio from the U66 to the U65 and then the switches worked. I don’t know what issues there could be from telling the radio it’s using a Bose amp when it’s actually a Delco? But everything seems to work ok. I have a feeling some of the difference is with the EQ settings. I know Bose likes to use their own presets programmed into their amps.
Now I just need to decide if I want to spend the $$$ on a new steering wheel…
thx for the write up....
#54
Folks, don't waste your money. You will never use these controls. I had a 2006 and wondered about converting to the radio controls then. Now that I have a 2007, I never use them. It is just too easy to reach the radio.
Besides, the controls are on the right side of the wheel. To be really handy they should have been on the left side. How many of you actually drive with your right hand on the wheel enough that you would use the controls? If you are like me your right had is resting on the shift lever.
TCW (08-11-2023)
#55
#56
I had a whole $25 invested in my conversion and I probably wouldn't do it again.
#57
my whole reason for wanting to do this was for hooking it up to an aftermarket adapter and then to my Kenwood 8120. I would think this would still work based on the other posts. The bottom buttons on that radio are very small and if you tilt the screen to a negative position they sink in even further. The steering wheel buttons soon became the best idea for me to try.
#60
Former Vendor
Does anyone who wants to upgrade want to trade their stock cover without switches for the actual controls and cover? I have a new wheel to swap on my 05, and it has the controls, which I don't want.
Even trade!
Even trade!
