06 Z51 0-60 Times
06 Z51 0-60 Times
I am baffled by my 0-60 estimates. I have used a stopwatch to check 0-60 times and the best I can get is in the 6 second range. It doesn't matter where the traction system is set/sport mode/or using paddle shifters. I have an 06 Z51 auto w/paddle shifter and was expecting sub-5 second times. Any ideas???
It's so hard to get an accurate reading with a stopwatch, especially while you're driving. It's also VERY hot out right now.
I also have an '06 A6 and based upon my best sixty foot and 1/8th mile times when it was still stock, the online calculators claimed that it ran a 3.45 second 0-60 time. I personally think that that's a little optimistic but this car was definitely running to 60mph in under 4 seconds on my stock 12.2 second 1/4 mile passes.
Yours will do the same once the cooler weather comes back.
I have a 08 Z51 auto and a G-Tech . Best I've gotten was 4.09 a couple of times.
The g-tech confirmed the stopwatch at around 6.0 seconds with a weight of 3500 lbs. I went ahead and did the 1/4 mile pass and it read 14.24@105 with traction completely off. The car does not feel down on power or run rough, but the numbers seem to be off.
I think your g-tech is ready for the trash...Get that car to the drag strip....
Are you brake torqueing the car at all or just nailing it from idle? The heat is also a big factor as well as your elevation. If your in Colorado I understand the times. Seems a bit slugish to me.. Go race somebody and see where you stack up!
St. Jude Donor '07-'08-'09
You should be doing much better than the times you provided. If your performance does not improve and you are still under warranty, I would get it to a dealership. If it is out of warranty, then time to go to a good speed shop and have them take a look.
blakedill, fill out your profile so we know what area you are in... or at least tell us.
I am in Abilene, TX. Not a very high elevation, but it has been 95+ degrees. I don't think this would slow me down as much as the stopwatch says. Also, I am just nailing it from a stop (no braked launches).
i think everyone is forgetting how slow 14.5 is for a quarter mile. my front wheel drive GTI with terrible tires does 14.7
stock turbo, about 240bhp. FWD!
perhaps a clutch problem?
replacing the stop watch was the worst idea.
