More tools from the pros at Katech - Bartec TPMS Trackside programmer
Old 07-22-2008, 12:51 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default More tools from the pros at Katech - Bartec TPMS Trackside programmer
If you have 2 or more sets of wheels for your Corvette this tool allows you to sync the TPMS sensors to the vehicle when switching back and forth.
* Bartec designed tool for high performance cars with TPMS
* Set up specifically for either GM, Ford or Dodge performance cars
* Train track wheel TPMS Sensors to your car
* FCC Approved
* Light weight and compact
* Carrying pouch included
The tool actually decodes the sensor data which ensures that the correct TPMS is being read and that the tool is not fooled by RF transmissions from keyfobs or other sensors. The tool comes in a kit comprising: tool, rubber protective boot, carrying pouch and 9V battery.
Instructions:
1. Switch vehicle to accessory mode
2. From inside the vehicle, hold the lock and unlock buttons on the keyfob simultaneously. The horn will sound.
3. Start with the LF tire.
4. Hold the Trackside against the tire sidewall near the valve stem. Hold the button and wait for the horn to sound.
5. Repeat for other tires in this order: RF, RR, LR.
6. When the LR is syncronized, the horn will sound twice. You are now finished.
Note: For HRE or other aftermarket wheels with the TMPS sensor in the center of the wheel you will need to put the Trackside on the tread near the sensor. Sync the sensors to the vehicle with the tires laid out on the floor, then install the wheels.
MSRP: $199.99
Corvette forum price: $139.99
__________________
Contact:
(e) zach@katechengines.com
Old 09-15-2008, 09:02 AM
Katech_Zach
This is not a special or a limited stock item. These are regularly in stock and $139.99.
Old 09-15-2008, 11:11 AM
07MontRedcp
Support Corvetteforum!
07MontRedcp's Avatar
How much is shipping and handling?? 85219
BJK
Old 09-16-2008, 11:35 AM
Katech_Zach
Here it is straight from Bartec, a complete application guide showing every car the Trackside will work with.
http://www.katechengines.com/street_...20Coverage.pdf
Old 10-08-2008, 04:46 PM
Katech_Zach
We are still offering these at the low, low price of $139.99. They are in stock and ship the same day.
To More tools from the pros at Katech - Bartec TPMS Trackside programmer
Quick Reply: More tools from the pros at Katech - Bartec TPMS Trackside programmer
