Help removing rearview mirror lights
EDIT: Here is your answer: http://forums.corvetteforum.com/show....php?t=2115076
1 Post
I assume you are talking about removing the bulbs? They are just held in by pressure. Basically all you have to do is pull on them, but they are in there so tight, it feels like they will break. Try squirting a little WD-40 at the base and see if you can get some needlenose pliers down on the base to pull on. And maybe a little wiggle from side to side.
