Livernois Motorsports LS2 Head/Cam Packages
Supporting Tuner
LS2 Stage 2 Head/Cam Package 1
LS2 Stage 2 Head/Cam Package 2
Typical gains from this package are 100+ HP
Note: Power levels may vary depending on testing conditions as well as individual vehicle
If you have questions, please pm me or email rleblanc@livernoismotorsports.com
Thank you
Regards,
Rick LeBlanc
- Livernois Motorsports Stage 2 CNC Ported LS-Series Cylinder Heads
- Livernois Motorsports Stage 2 Camshaft
- GM MLS Head Gaskets
- GM Exhaust Gaskets
- ARP Head Bolts
- Hardened Pushrods
- NGK TR5 Spark Plugs
- Kooks 1 7/8" x 3" Longtube Headers
- Kooks X-Pipe w/ Hi-Flow Catalytic Converters
- Halltech Cold Air Intake (Red or Black)
- ARP Head Bolts
- Hardened Pushrods
Thank you
Regards,
Rick LeBlanc
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
Rick- Do you have a dyno chart of the stage II setup? I'd love to see what the torque curve looks like.
Supporting Tuner
This particular car was a 2006 6-speed with everything included in the package and Flowmaster mufflers.
Thank you
Regards,
Rick LeBlanc
Thank you
Regards,
Rick LeBlanc
Rick: Several people have requested to see my dyno sheet, If you like you can post mine here. Thanks.
Supporting Tuner
Bob,
Attached is your graph.
Jahan, the LS3 package we've been doing is cam only since the LS3 has L92 heads and we've been seeing 490+ HP with our stage 2 L92 cam, dual valve spring package, headers, cai, and tune. This package installed is roughly $4,575.00
Thank you
Regards,
Rick LeBlanc
Thank you
Regards,
Rick LeBlanc
Bob,
Thank you
Regards,
Rick LeBlanc
Thank you
Regards,
Rick LeBlanc
Even if it's not, that's a good price. Does that include dyno time?
Supporting Tuner
It is RWHP and that is the installed price with dyno time and custom tune.
We installed our stage 2 L92 camshaft, dual valve spring kit, Kook's LT headers and X-Pipe w/ cats and a Corsa catback on a customers 2008 M6 Corvette and it made 489 RWHP / 436 RWTQ. This car has been a best ET of 11.23 @129 mph.
The specs on this cam are: 230/236 .590/.600 114 LSA
Here is the graph:
Regards,
Rick LeBlanc
Jahan,
Here is the graph:
Regards,
Rick LeBlanc
Here is the graph:
Regards,
Rick LeBlanc
Supporting Tuner
Regards,
Rick LeBlanc
I think that is Beefcake's car. Wow the stage 2 has a lot more power and torque. The TQ curve on the stage 2 is over 400 from 4k to redline, where the stage 1 falls off much sooner. Do you have a good idle video with the stage 2 cam? Will it pass the sniffer test in Cali.? Any bucking, surging, even at low cruising RPM (1300 - 1400)? Is there any advance in that cam? XE or XER lobes? RPM at idle?
Supporting Tuner
I cannot find a video of the stage 2 L92 cam, however I'd say it's between the LS-Series Stage 2 and LS7 Stage 2 at idle. You can hear the LS-Series Stage 2 here and the LS7 stage 2 here.
The stage 1 has no bucking or surging, and the stage 2 has a little bit under 1,500 rpms, but it's not horrible.
RPM idle is 900-1000 and there is no advance. Lobes are XER to my knowledge.
As far as sniffer tests, I can't guarantee it, but have had customers in CA order the cam and pass.
Regards,
Rick LeBlanc
