Installed a Progressive Shift Light
I've always thought a shift light was a good thing, but primarily for the drag strip. A shift light seems like it is a sort of a panic alert - you get no warning until it comes on, then when it does you have to act quick.
A couple weeks ago I was watching some Formula I racing on Speed Channel and the video that showed the cockpit showed lights on the panel that the commentator said were the progressive shift light that allowed the driver to keep the revs in the power band and alerted him as the rpm's built that he was getting toward the shift point.
I've got a Traqmate data-logger for logging my track day sessions. I was looking on their website last week and saw that they had a "progressive shift light" available. I did some research on it and decided to get it and try it out in my C6 Z06.
It wasn't cheap at $148 but it's nice and small for lots of mounting options. They have a "flat" one with a flat bottom and a curved top, and they have a "round" one that can be mounted around the outside of a motorcycle tach like you see above. They both have 7 lights, and you can get it with either 4 green/2 amber/1 red lights, or 5 blue/2 red lights. I got the flat one with green/amber/red.
You can set the rpm where you would like the first light to come on and where you would like the upper light and your shift alert to come on, the lights are programable to come on in several different styles, the brightness can be adjusted, and there are a bunch of other features.
The display unit is less than 3-1/2 inches long, 1 inch high, and about 1/2 inch thick.
It has 3 wires - ground, +12 volts, and the Tach signal. I pulled out the instrument cluster surround trim and fabricated a small bracket out of piece of metal bracket/strap stock and tie-wrapped it so the unit would be just above my instruments.
I hooked the ground wire under a bolt on the steering column. I found switched +12 volts in the red wire in the bundle going to the sensor just to the left of the ignition switch and used one of the supplied splice-clips to tap into that source of power.
I had previously tapped into a wire to the Tach behind the instrument cluster for an rpm input to my Traqmate, so I just spliced into that wire. Here's a picture from Pipedream's website that shows the back of the instrument cluster:
In the picture above Ed is holding the wire bundle going to the speedometer. The bundle to the left (the larger connector) is the one to the Tach. In that wire bundle is a white wire - that's the one you want to splice into for an rpm signal.
Here's a link to a thread by Pipedreams that shows how to get to that area:
http://forums.corvetteforum.com/show...ghlight=gauges
After hooking it up and closing up everything, here's a picture of it (the only thing I've noticed driving around today is that the way I have it mounted it I can only see the bottom half of the turn signal arrows):
The default setup has the first light coming on at 1,000 rpm and the shift point is set for 7,000. I need to figure out where I want the first light to come on at the start of the LS7 power band - I'm thinking 3500. I think I'll set the top of the power band to have the lights indicate the shift point at about 6,900.
I think I'll like the unit on the track during HPDE's. Instead of just a panic light when it's time to shift, this thing will hopefully keep me aware of where I am in the power band and let me know not just when it's time to shift, but will alert me as I approach that point.
Bob
Bob
Yes - a couple events at Daytona, at Sebring, and today at VIR where I'm attending the NCM HPDE today and tomorrow.
I set the low light (first one to come on) at 3,500 and they are on and flashing at 6,800 rpm (200 rpm below the 7,000 redline of the LS7).
It works great!!
Bob
It works great!!
Bob
Once you get it figured out see about posting a vid of it in action, I'd like to see it work
St. Jude Donor '09
Gotta give props to Bob. Great write up on the install. I followed along with my install of the shift light. Programed it the same.
Here is a vid at TWS a few weeks ago. Warning, the sound is crappy.
http://www.vimeo.com/4349064
Cheers
Cheers
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
very interesting, Bob, and great write up. did you consider putting it more in the line-of-sight? I realize that'd probably look more 'tacked on' than the in dash location you have.
1 Post
St. Jude Donor '09-'10-'11
Nice write-up and Nice install. Thanx for sharing. I totally agree with you re the benefits of the progressive lights--keeps you aware of your power band rather than the "panic" light of old.
The place I've got it works great. With the 7 lights progressively illuminating and then all blinking at the shift point you set up, it's very easy to see - it definitiely gets your attention when it's time to shift!
Bob
St. Jude Donor '15
"In honor of jpee"
Yes, I forgot about the wires. That would look tacked on.
It actually "auto-dims".
However, mine was set for the first light to come on at 3500 RPM, and another light came on at about 500 RPM intervals until they were all on and flashing just prior to redline (redline is 7000 in the Z06).
So.......for street driving I don't usually see more than 1or 2 lights and it never bothered me at all when driving at night.
Bob
Bob
St. Jude Donor '09
