Katech oil pressure pump shim now available
Premium Supporting Vendor
KAT-4899
$9.99
Oil pressure pump shim for all LS engines (including LS7) to increase oil pressure. Installs into the pressure relief spring bore to put more tension on the pressure relief valve.
$9.99
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
Yes
Oil pressure is a dynamic thing and I can't say this will boost Xpsi. It is a pretty big job to install. Similar to a cam swap.
I agree that oil pressure is dynamic but I would think you should be able to give a relative answer. Given the same circumstances one can expect a Y% increase in pressure. JMHO
