2006 Seat Switch Electrical Diagram?
I am in the process of putting 2006 C6 Z06 seats in my 2002 coupe. I would like to figure out how to connect the 6 wires from my stock power seat tracks to the C6 seat switch.
Does anyone have a wiring diagram for the 2006 C6 seat switch that they could make available to me?
Thanks.
Thanks.
Thanks.
The switch that is on the seats that I have has an 8 pin connector. Does your manual have picture of 8 an pin pinout?
The pins are labeled:
ABCD
EFGH
ABCD
EFGH
Thanks that looks right. It is kind of hard to read. It looks to me like:
A - Rear up
B - Front up
C - horizontal forward
D - Front down
E - B+
F - horizontal backward
G - Rear down
H - not used
Is that what you see?
My 2002 seat system is ground referenced and this one is B+ referenced. What I am trying to do should still work since they are just normally open switchs that complete a circuit.
Thanks a bunch to you guys for helping.
A - Rear up
B - Front up
D - Front down
E - B+
G - Rear down
H - not used
Thanks.
Thanks.
However, I'm not sure it's that easy.
Under the bottom of the Z06 seat you're installing you'll see a couple of boxes. All the wiring goes through these boxes. One is the seat controller, and the other is the box for memory functions. Here's a picture of my Z06 seat:
I don't know whether all the functions are the same in the C5 and the C6, and I doubt all the wiring is the same in your C5 and your BCM may not be compatible with the controller and memory box on the C6.
I hope you can get everything working okay - good luck!!
Bob
A - Rear up
B - Front up
D - Front down
E - B+
G - Rear down
H - not used
A - Rear up
B - Front up
D - Front down
E - B+
G - Rear down
H - not used
Below is a picture of the connector that you must be looking at, and it has the colors of the wires that may help.
Bob
I am going to be using the non memory seat track and electronics from my C5 seat. They bolt right on to the C6 seat.
I am hoping just to use the 6 way adjustment switch on the C6 seat to control the non memory electronics on the C5 seat track.
I hope the pictures of the connectors and schematics help you get everything working.
Bob
Bob
I just wanted to thank you guys for your help with the wiring diagrams. I did get the seats installed and was able to get C5 seat electrics working with the C6 seat switch.
I had to do some research on the net to get the correct Delphi connector shell and terminals (GM wanted way, way too much $$$). If you are ever looking for Delphi connector parts you might want to give http://www.mouser.com/ a shot.
I love this forum!
Thanks for all the information in this post!! Simply awesome.
Can anyone post a connector end view of C375 for a 2007? I'm looking into keeping the 2007 C6Z rails and electronics for my C5. In my 97, C301 uses 4 positions: orange, or/bk, bk/ bk/wht. Unfornately, my esi doesn't have a CEV for a 97, so I'm searching for the pinout of that as well
**I should also note: I do not have memory, and am not trying to add it (maybe later). I don't believe there is a way to control the seat heaters yet (without the PCM inputs), so that is also not a primary concern (although I'd really like to solve that one ) All I am concerned with at this point is powering the seat.**
Here's what I do have:
2004 C301 connector end view (for reference since I don't have the CEV for my 97):
2004 Seat Belt Switch connector end view (for reference since I don't have the CEV for my 97):
1997 seat schematic:
So I *believe* C301 in my 1997 (it only uses 4 positions) should be something like:
A = BK/WHT -- Seat belt switch signal - Driver
C = ORN -- Power seat breaker IP
D = BK -- Ground (G205)
E = ORN/BK -- SCM-L minifuse 4
From the above schematic, it seems like I'm looking for C375 instead on C301?
Possibly:
C375 A4 <--> C301 C
C375 B1 <--> C301 E
What I don't see from the C6 schematic is how to connect my ground (C301 D) or the seat belt switch signal driver (C301 A).
Hmmm. Maybe I should be looking for a pinout of the seat belt switch plug (at the seat belt buckle assembly) and take my C301 A directly to that plug some how)?
Ideally, where I'm headed with this is making and adaptor pigtail so I can preserve the harness ends on both sides.
Possibly:
C375 A4 <--> C301 C
C375 B1 <--> C301 E
