LG Mororsports Sawr Bar End Links Installed
#41
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
OK, forget I asked the question. Just post up in a new thread when you do put on new shocks----and wear a kevlar suit.
#43
I will be installing Z51 Sway Bars and plan on using the existing stock end links. If there is a distinct advantage in upgrading to the LG HD quiet end links, I will do so. However, I am on the fence as to the advantages of upgrading. I do not track the car but if the opportunity presents itself I will. After reading many forum member contributions, I come to the conclusion that the main advantage offered by the LG end links is their adjustable. Also, if the stock end links should begin to pop, squeek, clank or otherwise make noise, upgrading to the LG's can fix this problem. My stock end links are in great shape and will probably serve my upgrade to Z51 sway bars just fine. Am I missing something (other than the want or need for overkill)?
BTW, my car now handles like the Z51(with the Hotchkis bars) on the windy roads & High speed turns in & out of the freeways were the Gs,understeer etc.,can be felt,but retains the confort of the base suspension.Responsiveness can only improve with the removal of the squishy links. Hope this helps.
respectfuly,
ledfoot
#44
CI 3-5-6-7-8 Veteran
Just a word... the stock links aren't "squishy". Yes heim-jointed links are an upgrade but really only for the ability to set bar pre-load. Back in the C5 days the pre-2001 cars came with plastic endlinks. In '02 they upgraded to the aluminum ones that come standard on C6s. These were an upgrade over the plastic ones and are far from "squishy".
#45
You seem to be, again harping, on the word "squishy". Relatively speaking that word can be used to describe many things. I originally chose that word to emphasize the point that, as an additional benefit to what the OP said, heim joints remove the rubber isolators out of a suspension link, that are there in the first place, to reduce N/V/H.
In the picture above, do you not see rubber isolators in the OEM endlinks?
#46
^ Those are dust boots to keep the joint greased. It's a solid joint. Heim-joints technically need to be greased periodically. Cut that boot open and tell me what you find.
My point is that very few people need to buy endlinks like these... the majority are buying them for the wrong reasons. Just trying to help the average vette guy be fully informed.
So often you see something like this and all of a sudden everyone thinks they must have this item for the magic handling improvements. If you want to spend $300 on endlinks then by all means go for it. But to the majority of owners that money would be better spent on 10 tanks of gas and driving or an HPDE weekend.
#47
Mike
#48
Which swaybars do you have? Which endlniks do you currently have? LG developed these for guys who wanted to run GM's T1 bars on the street w/o the clanking. T1 bars come w/ heim-jointed links from GM, but they make lots of noise.
#49
I have Z51's bars & they are not squeeking after they warm up but I have noted an increase in road noise all the time.
#51
Bringing this back from the dead because:
A: I broke an endlink on the rear of my new-to-me 2012 GS
B: I read bad info repeatedly in this thread...
There is no SQUISH in the OEM metal endlinks. Matter of fact, where mine cracked, at the very TOP of the joint, is solid metal. some of you guys kept referencing some form of rubber used in the construction of that piece. The ONLY rubber is in the BOOT that holds grease. Yea, like Brian, I'm trying to impart some wisdom here. There is ZERO deflection on those parts. However, they apparently don't like cold weather and steep driveway entries... I'll post a pic of my destroyed endlink later to drill this point home even more.
Edit: started my own thread to discuss my break...
Mike Kelly
Mike Kelly
