Clutch and brake fluid
Old 03-16-2009, 05:41 PM
comes alive
comes alive's Avatar
Default Clutch and brake fluid
I own a 2008 Z06 and The manuel asks for dot 3 brake fluid, what fluid goes in clutch.I want to flush brake and clutch, thanks
Old 03-16-2009, 05:43 PM
patton
patton's Avatar
St. Jude Donor '09
they take the same fluid
Old 03-16-2009, 05:46 PM
comes alive
Default fluid
thank you sir.
Old 03-16-2009, 06:19 PM
slvr76
slvr76's Avatar
You can upgrade to DOT 4 if you want to. Depends on how you use the car if this will be beneficial or not.
Old 03-16-2009, 07:56 PM
Ragtop 99
Ragtop 99's Avatar
Received 1,167 Likes on 673 Posts
My owner's manual states DOT 4 for the clutch.
Hydraulic Clutch Fluid. Use only GM
Part No. U.S. 88958860, in Canada
88901244, Super DOT-4 brake fluid
Old 03-17-2009, 12:48 PM
ipmtim
ipmtim's Avatar
Cruise-In VIII Veteran
St. Jude Donor '06
Not unless they changed it from '06.
Dot3 for the brakes
Super Dot4 for the clutch.
Tim
Old 03-18-2009, 07:24 AM
foremaw
Support Corvetteforum!
foremaw's Avatar
St. Jude Donor '08-'09-'10-'11-'12
Your manual says DOT4 for clutch and DOT3 for brakes.
Old 03-18-2009, 09:10 AM
comes alive
Default clutch
Thanks all I sucked out the fluid in the clutch resevoir and filled it with dot 3. I have not ran the car yet so I hope im fine, im going to get rid of that dot 3 and fill it with dot4. Any name brand suggested besides gm that I could get from my local auto parts store. thanks again.
Old 03-18-2009, 11:25 AM
Wayne O
CF Senior Member
Wayne O's Avatar
Dot3 for the brakes
Tim
The owner's manual may say to use DOT-3 for the brakes and DOT-4 for the clutch but the recommended replacement fluid GM #88958860 is labeled "Brake and Clutch Fluid Super DOT-4." If they really want DOT-3 for the brakes you think they'd recommend and list a DOT-3 fluid.
I use Motul 600. Not all auto parts stores carry Motul but if you call around you'll likely find it. To purge the DOT 3 fluid which I assume you 'circulated' through the system many times, you'll need to drain, circulate and re-fill the fluid (with DOT 4) multiple times. I'd repeat the cycle a dozen times or more. For normal street driving I'd also recommend Prestone DOT-4.
Old 03-18-2009, 11:32 AM
comes alive
Default fluid
thanks wayne I never ran the car so hopefully ill be fine with a few times.
Old 03-18-2009, 01:12 PM
Ragtop 99
Ragtop 99's Avatar
I'm running that now. Didn't see the Motul in two autoparts stores in my area.
Old 03-18-2009, 03:38 PM
TCW
TCW's Avatar
St. Jude Donor '06-13,'16-'17, '19
This confuses me too! My brake master cylinder cap clearly says DOT 3 brake fluid. Perhaps there are some GM cars that do use DOT 4 brake fluid, thus the 88958860 part?
Tom
Old 03-21-2009, 06:27 AM
Hard Rock
Hard Rock's Avatar
Same here in New England can't find Motul any other brands? Or should I just pick up the GM fluid at the dealer.
To Clutch and brake fluid
Quick Reply: Clutch and brake fluid
