I think I found my turn key engine, what do y'all think?
Get Some!
http://www.golenengineservice.com/sp...402_550tk.html
My brother-in-law who knows a lot more about LS engines than me likes it, says the company has a good rep, and says it should have a very "streetable" idle.
LS2 402ci 550HP Turn Key
If you need tons of power for the street and strip, this engine will make it! This engine
will run on 91 octance pump fuel, idles at 900rpm, will run your stock A/C with no problems and will still turn 11’s at the track!
Peak Horsepower: 550 bhp @ 6500 rpm
Peak Torque: 545lb/ft @ 5000 rpm
Operating Range: 2500 - 6500 rpm
Compression Ratio: 11:1
Required Fuel: 91+ Octane Pump Gasoline
Base Price: Starting at $8999
Specifications:
Block: New GM LS2 aluminum block. Decked, bored 4.005”, honed with torque plates and pressure washed. New Durabond cam bearing installed, line honed, ARP main studs.
Crank: Callies 4340 forged steel, 4.000” stroke, internal balanced front and rear
Rods: Manley 4340 forged H-beam, 6.125” length, floating pin, ARP 2000 rod bolts.
Pistons: Manley 2618 forged with anti-friction coating
Rings: Mahle low drag plasma rings
Bearings: Clevite H-series main and rod bearings
Lifters: Comp Cams Hydraulic Roller
Pushrods: Comp Cams Magnum Series
Valve Spring Kit: Double polished springs, titanium retainers, hardened spring seats, hardened locks and Viton valve seals.
Rocker Arms: GM 1.7 ratio
Timing Set: Manley billet double roller, 9 key way bottom gear and Torrington bearing
Oil Delivery: Melling Select Performance
Gasket Set: Cometic MLS
Head Bolts: ARP Performance Hex Head
Covers: GM oil pan (to match your car), timing cover, rear seal housing, lifter valley housing and valve covers.
Intake System: GM L76 intake, 39lb injectors, fuel rails, Fast 92mm throttle body.
Damper: ATI Performance products
Manufacturer:
Comp Cams
Type:
Hydraulic Roller
Operating Range:
2500-6500 RPM
Idle Quality:
Good
Duration:
Intake: 230˚@ .050”
Exhaust: 236˚@ .050”
Lift:
Intake: .600”
Exhaust: .600”
Lobe Separation:
112˚
Heads:
Type:
GM L92 Aluminum
Combustion Chamber:
64cc
Flow: 330CFM @ .600”
Intake Runner:
227 cc
Intake Valves:
Manley stainless steel 2.16”
Exhaust Valves:
Manley stainless steel 1.59”
Specifications:
Manufacturer:
Comp Cams
Type:
Hydraulic Roller
Operating Range:
2500-6500 RPM
Idle Quality:
Good
Duration:
Intake: 230˚@ .050”
Lift:
Intake: .600”
Exhaust: .600”
Lobe Separation:
112˚
Heads:
Type:
GM L92 Aluminum
Combustion Chamber:
64cc
Intake Runner:
227 cc
Intake Valves:
Exhaust Valves:
It uses all top shelf parts and as long as it comes with a warranty, whats the risk?
I would want the installer to source the patrs for a real no risk venture but it is a good deal. I dont know the rep of the builder hence wanting this protection.
The thing that makes me feel confident is that there are conservative statements like low 11's for the 1/4 and the power production numbers.
Good luck with the project and thanks for your service in protecting us over there.
Let me know if I can do anything for you to help; lots of free-bees from me.
Get Some!
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
If you are gonna be in charge of that much power, you should be promoted to at least Lt. Colonel.
Be safe/smart, and come home in good shape to enjoy the car. Thanx for protecting us back here at home.
Get Some!
You're welcome. My M2 Bradley had 650HP but it also weighed 32 tons.
This should be a very nice package.
Just a note: We have had some durability problems with Manley connecting rods in race engines. If you have the option for Oliver or Carrillo rods, I would strongly consider it.
http://www.ls1tech.com/forums/genera...ter-1-day.html
May want to check this out. This is a Golen build, I don't know anything about them, but sounds like could be a problem. May want to check out HKE in Houston they always get rave reviews.
Get Some!
Get Some!
I couldn't find a turn key aluminum long block on their web site????
http://www.hkracingengines.com/ can you find them?
Get Some!
