View Poll Results: Did you take action?
Yes, I think its the right thing to do!
325
68.71%
No, I haven't the time for this.
148
31.29%
Voters: 473. You may not vote on this poll
Service Active Handling - Consumer Action
Old 07-10-2016, 11:25 PM
  #841
Got uid0
Got uid0's Avatar
St. Jude Donor '17
Originally Posted by SmileyOr
Each wheel has a plug that is the connection to the wheel speed sensor. Disconnect and apply the grease there at each wheel.
This has prevented my issues since last September. Other than one day when the Service Active Handling lights came on and didn't clear with a restart. Next day and every day since I have been fine.
Are you putting the grease on the rubber boot or on the actual pin connection locations?
Old 07-11-2016, 12:09 AM
  #842
SmileyOr
SmileyOr's Avatar
Right on the metal pins themselves.
Old 07-14-2016, 08:34 PM
  #843
Got uid0
Got uid0's Avatar
St. Jude Donor '17
I do not think that is well advised.
Old 07-15-2016, 08:31 AM
  #844
1972bluelt1
1972bluelt1's Avatar
I'd put the grease on the rubber and clean the connector with CRC electric contact/connector cleaner.
Old 07-15-2016, 08:58 AM
  #845
SmileyOr
SmileyOr's Avatar
I put it directly on the metal and have had only the one day that the SAH lights came on since September of 2015.
Old 07-15-2016, 09:12 AM
  #846
06Rawpower
06Rawpower's Avatar
Default Mileage
Originally Posted by tim87tr
I will file a complaint for this serious problem, in addition to the roof complaint I already filed (GM would not repair my roof that was about to fly off due to a previous "repair").
My active handling activates almost weekly at lower speeds while turning, even with the traction control off. The problem is it locks up the front brakes!! While this may not sound too serious at low speeds, imagine pulling out into traffic and the brakes lock up on your car. It occurs pulling onto grass or loose gravel also, especially in turns. I have to turn the car off and restart it for it to move again.
The problem first occurred last Fall and I finally addressed it with the local GM shop with TSB 06-02-35-0002B on 1/2/09 ($88.15 service), which added a clip to the SWPC connector. It did not correct the problem long term. I do have stock size street tires on my car also.
I'm a new to me 06 corvette owner, 3 weeks, my Vette has 31,000 miles on it. Is there a certain amount of mileage on these cars that start having these TC/AH problems? I haven't experienced any problems yet but I'm extremely concerned. This is my first Vette plus I don't need to be in an accident. My 06 Z51 convertible does have the telescoping steering wheel.
From what I'm hearing, I'm really glad that I didn't buy a coupe with tops flying off! Thank you for posting the safety issue bulletin!
Old 07-21-2016, 05:51 PM
  #847
partisan
partisan's Avatar
This is my first day of the noted problem. The DIC warning light stays on but I haven't had my brakes lock up yet. The local dealer charges $110 for a code test to find the problem. Is this a test I should have done right away or can I just turn it off and forget about it?
Old 07-21-2016, 06:00 PM
  #848
SmileyOr
SmileyOr's Avatar
Several things cause the DIC lights to come on. It's best to have it checked and repaired as soon as possible.
It could be the steering column connector, the wheel speed connectors at each wheel or the electronics unit that controls them.
Old 07-21-2016, 06:05 PM
  #849
partisan
partisan's Avatar
Thanks!
Old 08-15-2016, 06:47 PM
  #850
dreamvette05
4th Gear
dreamvette05's Avatar
Default Sudden brake application
Experiencing a sudden right front brake application at variety of speeds. Car had a trouble code associated with the steering position sensor. Dealer replaced sensor and examined the connector and clip on steering column. Supposed clip to fix problem was installed in 2010. Connector clip installation DOES NOT correct problem. After steering sensor replaced a second trouble code was detected concerning yaw sensor. Dealer is chasing problem and running out of options. Contacted customer service at GM and they are not willing to participate in either the repair or get to the bottom of the problem. Contacted NHTSA and only received a general response. In the meantime the car is not safe to drive as the brake locks at highway speed and below. By all means if experiencing this problem contact anyone who will listen. The dealer is checking the yaw sensor issue soon.
Old 08-15-2016, 06:54 PM
  #851
partisan
partisan's Avatar
Starting to make the Shelby GT 350R look better and better.
Old 08-15-2016, 07:22 PM
  #852
dreamvette05
4th Gear
I agree!!
Old 08-22-2016, 12:57 AM
  #853
cormudd
cormudd's Avatar
Originally Posted by lottavettes
Is it problem only with the telescopic steering wheel option?
Oh Oh
Old 08-22-2016, 01:04 AM
  #854
cormudd
cormudd's Avatar
Originally Posted by Marconi7
Where do you put the grease? Isn't dielectric grease used as a insulator?
Some electric grease conducts but prevents corrosion. Some does insulate but is for specific applications. Ham radio stores sell a dielectric grease for large antenna connection points. It prevents corrosion but allows conductivity from metal to metal. One of those things where you really have to do the homework before you buy...
Old 09-03-2016, 12:38 PM
  #855
Blackpunisher
Blackpunisher's Avatar
Default Another Vette with Service Active Issue....
Originally Posted by novaz06
Any luck with this? Thanks for taking the initiative. I contacted the listed personnel about my experience.
Hello and is nice but unfortunately have same problem to other people
Just got my Corvette about 1 Month and realize this issue. Really is not good and with forum I have ready contact the DOT
I hope they will resolve this problem
Thank you to all
Enzo
Old 09-07-2016, 10:09 AM
  #856
corrado
corrado's Avatar
2021 C6 of the Year Finalist - Modified
Having all 3 traction/anti-lock brake/active handling lights come on. Scanner reading 2 codes for drivers side rear wheel speed sensor.
Has anyone tried replacing the wheel speed sensor harness with any success? Can get them on Amazon and other sites for about $30, easier and much cheaper than replacing the whole sensor hub. Should I try it?
Old 02-19-2017, 09:31 AM
  #857
red500man
red500man's Avatar
I am looking to buy a c6, is this problem on all years or are some not included in this problem?
To Service Active Handling - Consumer Action
Old 02-19-2017, 10:54 AM
  #858
dreamvette05
4th Gear
Default brake lock up
As far as I know it applies to 2005 and 2006 production years. There is a crossover to other GM product lines within the same time frame exhibiting the same problem. A replacement of the steering position sensor and the yaw sensor has seemed to "solve" the problem. I am still wary of the situation. If it occurs again I will disable the system manually which is possible by holding the traction control button for ten seconds or more. GM seems to very aware of the problem. NHTSA has been no help even after thousands of complaints. I have reported it but have had no contact from anyone at NHTSA. GM has issued a voucher for partial reimbursement for the repair but it required a lot of persistence to get them to move forward. I would not let this deter you from buying a C6. It is a great car and I am sure this will get solved. A lot of fun for the money!
06Rawpower (02-19-2017)
Old 03-07-2017, 07:18 PM
  #859
mmorse
mmorse's Avatar
i have an 08 andit has reared its ugly head on a couple of occasions. i just move the steering wheel a little and it clears up for a time.
hippiefreak67 (12-26-2019)
Old 04-25-2017, 02:01 PM
  #860
Anthony_08
4th Gear
Anthony_08's Avatar
Just called the 1-800 number provided for NHTSA and filed my complaint as mine is doing the same thing.
Quick Reply: Service Active Handling - Consumer Action
