C6 convertable Photos with Roll Bar Installed
Thought i would share some photos for eneryone interested in having a roll bar installed without going through waterfall.
Let me know what you think.
Ron,
That is a FABULOUS install!!!!!!
Please, more pictures on the "details"..... under the floor,
the mounting to the frame or ?, connections,
etc., etc.
Since I am in Canada I doubt if I am going to drive to your area to get it done,
so if I can get enough info/details/pictures, I can probably get it done up here.
Thanks a TON !!!!
etc., etc.
Thanks a TON !!!!
Looks amazing. Congratulations on the install! Can you give us more information about this setup? Does it completely work with the top? Did anything have to be removed?
Works great with top up or down,Just had to remove seperation from trunk area where rear speakers are mounted so the rear supports could be installed.I will reinstall it when i get some time to lay it out, im sure it will work.
I am 5-11 and over 200 lbs have the seat about where i had it before only lose about 1-1/2 inch from the rear bottom of seat. The sides of the seat are very snug but seems to be fine.
Moderator
Received 3,570 Likes
Ron, are the door bars removable?
Awesome Car - love the top
It is bolted and welded. Extra plate is welded to frame then other plates ar bolted through.
Complete roll bar is removable from car at any time.But the plates that are welded to frame stay.
How much???
Will they sell the bar system as a pre-bent kit that can be installed by a local shop?
To be NHRA legal, doesn't the bar behind the seats have to be straight? In addition, I hope you have approved roll bar padding, even in a minor fender bender on the street you could be seriously injured by your head bashing against the steal bar.
NHRA looked at the car while bar was being installed at the shop as he was at the shop certifing a frame on a dragster and said they would only certify for 10.99 due to it being a convertable'And the bar is above my head not behind it.
For NHRA purposes roll bars are only good for 11:49 to 10:99, after 10:99 a full cage is required. For all the trouble of that bar set up, you can only get a 1/2 second quicker as opposed to a removable hard top like this one http://www.smoothline.com/corvette_c6.php . Per the owner of my local track, a vert with a hard top on it would be treated as a coupe and would be good to 11:50 with no other modifications needed. For me, the hard top is a better deal than the bar. Of course nonof the is applies to road courses.
And don't these run well over 2 grand if you purchase from the company?
(EDIT: just say the price on the link... $2699 and that's probably not including tax, shipping, and whatever extras the company might tack on.)
Your last sentence is the reason why I completely avoided the path of a hardtop for my convertible. I'd like to run regular road course events with the convertible and I don't think a removable hardtop will serve me well in a roll over.
