upgrading suspension...to what
I have a 09 C6 M6 Z51 and took to track all day on Monday (road course)..the car was great but wanted to upgrade suspension/sway bars etc.....the car creeks over bumps and rough pavement after the track day I think do to the hardcore driving I did..I wanted a good track setup..what suspension would you recommend? Z06 sways?????? I will plan to have better rubber then stock tires for track days.
trapp
trapp
Former Vendor
IF you are pretty new to the sport, just drive the crap out of it for a bit. Then figure out were you would like to go from there. Work on the brakes, driver, suspension, cooling and then horsepower-aero. Sorry I don't sound like a sales guy right now, and in this economy I should be trying to sell fart in a bottle.
When you are ready to start buying parts, please keep us in mind
Randy
www.dougrippie.com
Randy
www.dougrippie.com
buy some decent tires, get a good alignment, and work on the nut behind the wheel until you get a feel for more specifically what you need/want ("upgrade" could mean a ton of things)
CF Senior Member
Randy
www.dougrippie.com
Randy
www.dougrippie.com
Your Z51 equipped C6 can no doubt exceed your own capabilities at this point. I'd concentrate on getting consistent seat time for at least one season before jumping into whatever. Even when buying a dedicated set of track wheels/tires there are various considerations which may change as you progress into the sport. You might buy something now only to discover you should have done something different. Track your car often and concentrate on the fundamentals at this point. You'll get a better insight into what mods you might want to do with more experience.
I'm a little confused by your inquiry "...F55 with Z06 sways??????" If you don't already have the F55 suspension your chances of retro-fitting it to your non-F55 equipped C6 are vitually nil for all practical purposes. Besides, while the F55 with Z06 sway bars actually works pretty well on a road course it's not the ideal track setup.
trapp
trapp
I just finished my second track event (after) upgrading my C6Z's with suspension, brake upgrades and cooling (brake and engine) upgrading. I did several track events before the upgrades for seat time because it is the most important part of the equation..."you". I went with Pfadt's (not a plug, I just chose them) complete suspension set up (Aggressor 2 pkg), LG's - stop tech's rotors, cobalt XR-2 pads and SS lines, coolings ducts, motul RBF600 and did the events on Invo street tires.....btw, all before I go to R comps. You can mask serious errors this way. just IMHO.....
trapp
I am starting a thread and will have pics of the Pfadt components on as well either today or tomorrow. You can see for yourself.
BM
Former Vendor
The most important thing would be to get a proper alignment. This will give you more feedback and the harder you push the more grip you will have. Not like with a factory alignment which works against you. Then the shocks should be dealt with next, the shocks offer the most bang for the buck and really improve the feel and control the extra movement the car is doing. Bushings, swaybars and spring rates come next in the important stage. The best way to cure a bad handling car is to install new race rubber.
Randy
Randy
