Best C6 Z51 replacement rotors
My rotors are shot with 8k miles after burning through 4 sets of pads (3 stock z51 sets and one set of Carbotech XP10 front/XP8 rear).
So, what's the best value replacement rotor? The fronts definitely need to be replaced and I need another set of pads front and rear?
Oh, I track the car (obviously), so a good combo set is ideal, but willing to swap pads between street/track as I've gotten pretty good at swapping pads.
I searched the forum, but couldn't find any definitive solutions.
Anyone else have input on replacement rotors for an '08 Z51 C6?????
There's a whole section on brakes in this month's issue of 'Vette magazine. DBA (Disc Brakes Austrailia) has Z-51 size rotors, but you might think about upgrading if you are going to continue with heavy track use. West Coast Corvettes offers factory Z06 brakes complete kit, rotors, pads, ss lines and Motul on sale for $1700. But then you will need new wheels to clear the calipers.
grins,
Don
grins,
Don
you want cheap or good? I put DBA 4000 series slotted on,very high quality, with heat stripes, changes color at different temps. autoanything.com has alot of choices
On a semi-related note, I checked your profile and you dont list any brake upgrades. Your pads and rotors would last a little longer with some ducting to keep them cooler. Z06 brake ducts are a real inexpensive and quick install mod which would help a bunch. LG makes some killer looking looking pieces which will provide better cooling right where it needs it. Im deciding right now which of the two to go with for my car.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
