Opinions on drag racing tires
I'm tired of spinning and 2.00 60' times so its time for a change. I've got a set of 17 X 9.5 C5 Z06 front rims coming and I need some help making the decision on which tires to get.
Here's the choices I've come up with:
MT ET Street drag radials
Nitto NT555R
Hoosier drag radials
Hoosier 28.0/10.0-17 slicks
Will the Hoosier slicks hook that much better than the drag radials to be worth the trouble of having to change tires at the track? If not, which drag radial are you guys having the best luck with? From what I've read the ET Streets seem to be the favorite. Also, what tire pressure are you guys runing?
Nitto NT555R
Former Vendor
1 Post
Cruise-In III Veteran
Cruise-In V Veteran
Personally I'd go with the ET Street as I believe they take some of the drivetrain shock out of a hard launch, but many have sucess with the Hoosier Drag Radial. You can drive to the track on Both.
I'd go full slicks if your pushing big, big HP.
Location: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Nitto NT555R
Nitto NT555R
I ran with 275/40/17 MT ET Street radials (at 18psi) for over two years and used to think they were the best until a friend turned me on to the Hoosiers (also at 18psi) and with the same size tire I'm now cutting consistent 1.4 60ft times:
http://forums.corvetteforum.com/c6-t...129-95mph.html
http://forums.corvetteforum.com/c6-t...132-717-a.html
In addition to hooking like crazy at the track, the other thing I noticed about the Hoosiers (as compared to the MTs) is that if you get any kind of significant wheelspin when you launch the car they will actually rehook so the entire pass doesn't end up being a waste. When I was still using the MTs and didn't get a solid launch I pretty much knew right away that my time for that pass would end up being lousy.
I was tempted to try out the Hoosier slicks but since a slick generally tends to have more rolling resistance than a drag radial I'll probably just stick with my current setup.
Hope that helps,
Christopher
The Nittos might be a good street tire but they pretty much suck at the track.
Hope that helps,
Christopher
Hope that helps,
Christopher
This is the kind of first hand experience I'm looking for. Have you found the Hoosiers to be as sensitive to burnout duration as the MTs? I've read posts by Ranger that say do a big burn out before the first pass and a little one before all the rest because if you do to big of a burnout before the second and subiquant passes the tires can get greasy due to too much heat. Also, have you ever had the Hoosiers in the rain? I'm in southern Louisiana and small, sporatic showers are a fact of life. While I'll only be running the drag radials to and from the track, some nights (like last night) there's a small shower on the way home.
With both types of tires I get lots of smoke on the first burnout then let the tires dictate the length of the subsequent ones in that I'll listen for the engine RPM to start dropping (while maintaining a constant throttle) which means they're getting sticky. I also make sure to check my tire pressure before each run as they can change quite a bit based on the outside air temps.
I've never gotten the Hoosiers wet but did almost get into a wreck once with the MTs while doing 65 on the freeway and it started to rain. I had always thought drag radials were only a concern if you got on them too hard or punched it going around a corner but I was on a flat section and the car just started weaving back and forth. Since the Hoosiers have even less tread (if you can even call it that) I would't recommend them for any driving away from the track.
I've found the Hoosiers to be more forgiving if you don't do a decent burnout as I've cut some pretty decent times after doing one I thought was too short.
That's kinda what I thought. With those two tiny grooves they're basically cheater slicks. But if I have to change tires at the track would the new slicks be a better alternative? Which do you think would last more passes?
As far as what lasts longer/more passes between Hoosier drag radials and slicks, I would think it's pretty close, though M/T drag radials will certainly out live both in most cases though.
Your profile lists the car as stock. Are you planning to add mods? I did low 1.7s on 16" nitto drag radials on my much heavier F-body. Just don't over-tire (e.g. Hooiser 28" slicks) if you are staying near stock as that will slow you down.
Added the Vararam last week, getting ready to do headers and will get a Chuck CoW tune when he visits Houston later this year.
Subfloor do you drive to the track on the Hoosiers or change them after you get there? I noticed the Hoosiers have a "don't use these on the street" warning on the web page.
He's got an NA A6 and without a torque converter or 3.42s. No tire will get him much better than a 1.90. If he over tires the car, he will go slower.
