Stock Exhaust
Stock Exhaust
Dose anyone know how high I would have to have the back end of the car to remove the stock exhaust without cutting it, all I have is jack stands and a floor jack, its on an 07 coupe.
St. Jude Donor '06-'07-'08-'09-'10,'14
I did it with both the front and rears 6 inches off the ground on 2X12's. I then used jacks on the two rear jacking spots to raise the body probably another 4 inches but stopped well before the rear tires come off the ground. It took a little work the first time but not bad. The second time I did it was even easier. Not much force is required. You just have to figure out the right angle to come down over and twist and it comes right out. Having it higher would have been easier but not absolutely necessary.
