C5 Wagon Wheels, Spacers?
Thinking of running old 17x8.5 1998 corvette wagon wheels with some drag radials. Anybody know if I will need spacers? and if yes a rough idea of what size? I have a 07 z51 c6. Thank you in advance for your time. Drag strip use only
Wagon Wheel Offset: +56
Received 2,061 Likes
I'd suggest 17 x 9.5 wheels, not 8.5, so you don't excessively crown the DRs.
Sawblades are fairly light, inexpensive, and fit fine, they just look a little funky on a C6.
They'll work fine. I have a set of 275/40-17 Nitto Drag Radials mounted on 17 x 8.5 wagon wheels and even though the rim is 1/2" narrower than recommended, the tires work good and are not crowned. The wheels fit over my stock Z51 rear brakes with plenty of clearance and I do not run spacers.
One other benefit of this setup is weight. The 17 x 8.5 wagon wheel is very, very light and so are the 275/40-17 drag radials.
Good luck.
Good luck.
Also true. But it might be worth noting that Nitto drag radials do tend run slightly more narrow than other tires of the same size (ie: their 275 might appear closer in size to other manufacturer's 265s) but either way any 275 will still work fine on those rims. One can also consider the 17" M/T ET Streets (bias plies) as they're listed as 'ok' for an 8.5" rim.
True, the 8.5s work but are are not an ideal fitment for a 275-40 tire.
Here's a quick tire size differential calculator.
http://www.discounttire.com/dtcs/infoTireMath.dos
