Odyssey Battery Install - 2008 C6 Coupe
2019 Z06 2LZ A8 Coupe
I've done some research, and found that the Odyssey 34R-PC1500 fits perfectly in my 2008 coupe. Here is a link to the specs and dimensions of this battery:
Odyssey 34R-PC1500
Here's the research info, and pictures. Note that I have no connection to GM. Special thanks to Bugman and his great site.
Disclaimer: The information listed here is correct to the best of my knowledge. GM and or Odyssey might change specifications of their parts and part numbers.
First, a little background on the C6 coupe batteries and trays. According to my research, C6 coupes came with the following batteries and trays from the factory:
Year / Battery Group Size / Battery Tray P/N
2005 86 10268430
2006 90 10352084
2007 90 10352084
2008 85 10268430
2009 85 10268430
As you can see 2005, 2008 and 2009 use the same trays. 2006 and 2007 models use a different tray. 2005 cars use batteries with the postive post on passenger side of the battery. 2006-2009 cars use batteries with the positive post on the driver side of the battery (also called "reverse" post).
Battery Sizes, in millimeters, as listed from AC Delco and Odyssey:
Group Size / L W H
34 260 173 200
35 230 175 225
85 230 173 203
86 230 173 203
90 242 175 175
Odyssey 34R-PC1500 256 172 199
As you can see, the Odyssey is a replacement for group 34 batteries. Bugman has already shown that a group 34 Optima battery fits. I wanted an Odyssey battery, however.
Getting back to the battery trays, the 2006 and 2007 trays are wider than the 2005, 2008, and 2009. Part number 10352084 on left, and part number 10268430 on the right:
The smaller 2005, 2008 and 2009 tray, part number 10268430 fits the Odyssey 34R-PC1500 battery better than the wider 2006 and 2007 tray. Here are a couple of comparison shots:
Odyssey 34R-PC1500 battery in 2006 and 2007 tray:
Note in the 2006 and 2007 tray, the hold down clamp needed to be pushed full travel towards the battery. The battery was not securly clamped to my satisfaction, as the battery could still move in the tray.
Odyssey 34R-PC1500 battery in 2005, 2008, and 2009 tray:
The Odyssey 34R-PC1500 battery in the 2005, 2008, and 2009 tray fits perfectly, and the hold down clamp secured the battery properly.
Here are some pictures of the Odyssey 34R-PC1500 mounted in my 2008 coupe:
Additional Notes:
One of my concerns was access to the cabin filter door. Some have used a group 35 battery, but the group 35 is an inch taller. I believe an inch taller battery would have blocked the cabin filter door. The Odyssey 34R-PC1500 is no taller than the original battery.
Odyssey also makes the model 34-PC1500, which has the posts on the proper sides for 2005 cars. Battery dimensions and specifications are listed as the same as the model 34R-PC1500, other than not having "reverse" posts.
Conclusions
In my opinion, if you want the best battery with the most reserve capacity, the Odyssey is the way to go. Based on my research, here are the combinations that should work for the C6:
2005 - Buy the Odyssey 34-PC1500 battery and bolt it in.
2006 and 2007 - Buy the battery tray for 2005, 2008, and 2009 cars, GM part number 10268430. Swap out the tray. Buy Odyssey 34R-PC1500 battery and bolt it in.
2008 and 2009 - Buy Odyssey 34R-PC1500 battery and bolt it in.
Enjoy
Odyssey 34R-PC1500
2005 86 10268430
2006 90 10352084
2007 90 10352084
2008 85 10268430
2009 85 10268430
Group Size / L W H
34 260 173 200
35 230 175 225
85 230 173 203
86 230 173 203
90 242 175 175
Additional Notes:
Conclusions
Enjoy
grocerygetter (03-16-2017)
St. Jude Donor '09
Or you could save 17 pounds of weight and spend less.
http://forums.corvetteforum.com/c6-t...tall-pics.html
San
San
San
San
On the other hand, the Odyssey 34R-PC1500 produces 880 Cold Cranking Amps and has a reserve capacity of 135 minutes. It also has a Deep Cycling Capability of 400 cycles at 80% depth of discharge. A lightweight battery cannot produce that level of performance.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Good info, Klaus. Thanks!
St. Jude Donor '09
True, if you're looking to save money and weight that's the way to go.
San
Nice post! An alternative for the 2006/2007 folks is what I just did; install the PC-1200MJT. It is a perfect fit, although it does require a HDS hold-down strap instead of the GM wedge as the sides are straight. No need to buy and install a new tray.
Larry
Larry
This is the most useful information I've read on this forum. Thank you.
Follow-up: I installed the 10268430 tray ($12.50 from closest Chevy dealer) and the Odyssey 34R in my 06. Your advice was on the money. The fit is perfect, and the cabin filter door is still accessible.
Thank you, again.
Thank you, again.
St. Jude Donor '15
"In honor of jpee"
I know Summit Racing does, and if you go to Odyssey's site, they have a dealer locator per state like this:
http://www.odysseyfactory.com/locator.html
Man... I ordered the PC1500R because of this thread. I have a 2008. I didn't realize that some corvettes don't have the battery in the hatch. My battery 'tray' is a different size altogether. Looks like my battery location is 7.25" x 11.5". My battery clamps down with two bolts and a cross member. Oh well, hopefully when the battery arrives in the morning it will still work. My fault for assuming this would work for other models for 2008 :-)
I know a PC1200 MJT will fit in a 2009 Zo6. But since the battery is in a compartment you dont really need the Metal Jacket.
So you can drop the MJ off the end of the P/N
MJ=Metal Jacket
T = Terminal posts(not side post type)
MJ=Metal Jacket
