Shark Bar vs. Brey Krause Harness Bar?
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
Does his setup cause the shoulder harness straps to exceed the recommended departure angles from the bar? This is usually level to 10 degrees below the shoulder line.
In the picture it looks like the strap goes from the bar down through the holes then back up over the shoulder. Maybe it's just the pic
Here are a couple pics with the seat in the right position. These give a little better angle.
harness bar vs roll bar?
Getting ready to order a harness bar and am down to two options. Shark Bar or Brey Krause. Application is for a 2010 Grand Sport.
Shark Bar looks like a cleaner install, nice grommets and no exposed bolts. However, it does not look as strong as the Brey Krause bar.
Looking for feedback from those that have one or the other.
PS> Hardbar is out of the running as I don't like the mounting, too easy to twist the bar, not good for a camera mount.
I realize this thread is old but Google brought me here so Ill add what I found. It may help someone make an informed choice.
The directions for the BK bar show the bracket inside the panel and it looks beefy compared to the sharkbar.
http://www.pfyc.com/supportfiles/c62026install.pdf
At the bottom of the install directions for the sharkbar it says "Vetteworks Harness bars are for low speed applications only"
http://vetteworksonline.net/acrobat/...orvette-r2.pdf
I plan on tracking my car so the Sharkbar is out.
JeremyMalin (10-25-2020)
Received 1,679 Likes
I run the BK in my C5Z...very nice piece.
