ECU to coil diagram
ECU to coil diagram
Looking for the coil 1 signal on a 6.0L LS2.
Someone sent me a copy of pages 6-386 and 6-387 from the manual, showing the 72 way connector, but there is no listing for coil one.
Ignition Coil 1 Control: pin ??
Ignition Coil 2 Control: pin 66
Ignition Coil 3 Control: pin 61
Ignition Coil 4 Control: pin 58
Ignition Coil 5 Control: pin 59
Ignition Coil 6 Control: pin 57
Ignition Coil 7 Control: pin 53
Ignition Coil 8 Control: pin 65
Thanks for any help.
Supporting Vendor
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
This is from an 05 LS2 All the other pinouts match. IC 1 would be pin 54
53
OG
2127
IC 7 Control
54
PU
2121
IC 1 Control
57
L-BU/WH
2126
IC 6 Control
58
D-GN/WH
2124
IC 4 Control
59
D-GN
2125
IC 5 Control
61
L-BU
2123
IC 3 Control
65
PU/WH
2128
IC 8 Control
66
OG/WH
2122
IC 2 Control
53
OG
2127
IC 7 Control
54
PU
2121
IC 1 Control
57
L-BU/WH
2126
IC 6 Control
58
D-GN/WH
2124
IC 4 Control
59
D-GN
2125
IC 5 Control
61
L-BU
2123
IC 3 Control
65
PU/WH
2128
IC 8 Control
66
OG/WH
2122
IC 2 Control
Thank you so much, John has done this for me and I appreciate the quick response and efforts by you guys in the US.
It is for an LS2 engine with the E40 ECU
Big thanks from down under
