Nick Williams 102mm Throttle Bodies
Former Vendor
Nick Williams is known for making some of the highest quality throttle bodies on the market. This is a great addition to the FAST LSXR 102mm Intake Manifold.
Nick Williams 102mm Throttle Body (Drive by Wire) $575
* New LS2/LS3/LS7 version
* No harness required
Are these 102's very common on simple LS2 or LS3 NA cars with stock displacement? I seem to see these the most on larger displacement or more radical setups. Are they tough to tune on just a simple H/C LS2?
Probably dumb questions just curious if they're out there on stock displacement builds.
Great looking TB and it would be cool to have the 102 with my Fast 102.
Former Vendor
I kind of have stupid question on this TB.
I know that it's 102 mm inlet diameter on the intake manifold side, but is it also 102mm on the CIA side? I ask this becase if it is people would need some type of larger adapter for the CIA right?
I know this is a super retarded question probably, but from the pictures it looks like it's reduced down enough on the CIA side to fit a stock sized CIA inlet.
Former Vendor
Does your silicone coupler come with the hole to put that breather hose (or whatever it is). I am thinking of buying this just don't want to have to look around for the right coupler just wanting to buy it all at the same place.
102, 102mm, body, contact, drive, drive by wire, info, nick, nick williams, performance, sale, throttle, throttle body, williams, wire
