Plastic guard under front bumper
Cruising
Hey Guys,
First post, new 2006 owner as of two days ago!
A quick question regarding the plastic 'skirt' underneath the front bumper (black plastic lip that hangs down about two inches) What is this piece called? I've been searching to no avail looking for info on this. It is 3 pieces and my one end seems to have popped the plastic screws that hold it in place and is now dragging when I drive.
The guy before me had it wired together (poorly I might add), but I want it back in perfect form. Any info or links to previous threads on this would be great. I'm sure it's a common issue, just can't find anything on it!
Thanks!
Thanks!
Hey Guys,
Thanks!
Thanks!
Genuine GM 2005-2010 Corvette Exterior Specials @ GM Parts House
C6 Splitter / 3 Piece Air Dam
Stock C6
21992641 – Center air dam – $58.90
10301851 – LH air dam – $16.95
10301852 – RH air dam – $19.07
This is the three piece spoiler underneath the front bumper.
Z06
10342936 – LH air dam – $26.23
10342937 – RH air dam – $26.23
This is the three piece spoiler underneath the splitter.
Check with Gene Culley a forum sponsor. See link:
http://forums.corvetteforum.com/c6-p...rts-house.html
SUBVETTE
The air dam directs air flow up through the front facia bottom opening to the air conditioning condenser and radiator and also is designed to help aerodynamic air flow under the car.
Cruising
Thanks for the quick response!...those are the parts I was referring to. Looks like one of the plastic screws popped out on my right air dam, should be an easy fix for that one.
